SuperCharger Tuning Help
  • Thread starter Thread starter black50
  • Start date Start date Mar 19, 2009
black50
36
  • Mar 19, 2009
Have a couple of questions concerning tuning on a supercharger?
What should the base timing be with running a 10-13lbs of boost?
I pulled the spout and set it to 8 base, car wouldn't idle unless I adjusted the TB "accufab 75mm" to dump more fuel. But as soon as I put it in gear the car falls on its face. so it running really rich.
Where should the tps be set at on voltage?
Car has a FMU, I'm running a vacum tree right off the Intake Manifold. has a 6:1 fuel ratio disk in it. Is this correct for 38lb injectors?
At idle considering the FMU, how much fuel pressure should I have at Idle?
Currently sitting at 40-42lbs I heard that FMU dump 12 lbs for every lb of boost, don't know if that is true
How much Vaccum shoud be reading on the boost Gauge at Idle?
think its reading 12lbs
what would be the best sequence in tuning?
I don't have a really nice bypass valve, its adjustable with different spring rates I have the the lighest spring in there right now, I ran the vacum line straight from the tree on the intake manifold. however when its hooked up to the inlet pipe, and powerpipe, the car runs like **** barely can't get it to idle right. so I have a it off right now..and I'm not getting all the boost I should be.
Just trying to get the car tuned right...
Please someone give me some advice before I set this car on fire
thanks in advance
M
Mike in Texas
121
  • Mar 20, 2009
Supercharger tune
Having just installed a paxton 1220 sl, here's my input. You can get the car running ok on your own but to get the performance right you will have to get a dyno tune.
You need to post the mods on your engine for the guys that really know to be able to help but here are some general answers:
Base timing - 10-14 degrees depending on what your car likes. You will need a timing boost retard to dial the timing back during boost.
TPS - set at .9 - .98v
FMU: 6:1 or 4:1 if you're running rich at idle, the 6:1 is probably right for you.
Fuel pressure: 36 - 40 with vac off.
Tune Sequence: I'll leave that to the guys that know more.
Bypass: what do you mean "hooked up to the inlet pipe" and "powerpipe"?
Vacuum - a lot of variables, with my e303 cam I get ~ 12 on idle.
Tip: your MAF is a major factor with an SC
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Mar 20, 2009
  • Mar 20, 2009
set the base timing to 10 degrees with spout out.
set the FP to 39 psi (no vac on reg)
and take the FMU off and a get a properly sized MAF and injectors and get a custom tune.
will make more power, be safer and drive 10x better.
bubba-dough
1,044
Indiana
Mar 20, 2009
  • Mar 20, 2009
set the FP to 39 psi (no vac on reg) and take the FMU off and a get a properly sized MAF and injectors and get a custom tune. will make more power, be safer and drive 10x better.
Assuming you weren't having any problems before the s/c install, and that everything is installed correctly, starting point settings should be like mentioned with the addition of the tps @ ~1V.
Plus FMU's are junk band-aids. Get the proper size injectors.
If you have a pretty good set-up with mods a dyno tune wouldn't be a bad idea.
black50
36
  • Mar 20, 2009
I have lucas 38# pound injectors, Pro M 88mm MAS setup calibrated for 38's
The Motor is a 304 forged shortblock 9.5.1 compression on the keith black pistons, Crowler 512 lift cam 1.7 roller rockers, edelbrock RPM heads, edelbrock RPM II intake manifold, accufab 75mm TB, All MSD ignition, coil, 6al, pro billet dizzy.
I understand going to the shop and dyno tuning would be the best route,
However I'm a die hard DIY guy, and enjoy the experience in learning, and sharping my mechincal skills. this car is one of my hobbies, and excuse not to be in the house, I've spared no expsense so far on this project. Good detailed info would be nice!
I know there's alot of variables that could be affecting the cars performance thats why I'm asking specific questions so I can take those factors out of the tuning.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Mar 21, 2009
  • Mar 21, 2009
i'm the DIY kinda guy too, you know you could tune the car yourself, using a tweecer or moates QH.
trust me, actual EEC tuning is the way you need to go. will make more power and exhibit awesome drivablilty and be safer.
IMO a car gets to the point where tuning is almost mandatory. a power adder almost always falls in that category.
i used to run my old blower setup untuned with an FMU etc etc, i thought i ran good enough then i go to tuning the car myself and i was amazed at the difference it all made. granted there is a learning curve but its worth is in the end.
black50
36
  • Mar 22, 2009
yeah I'm stumped
I'm getting really frustrated now.. so Im going to dyno tune the car, and get a chipped burnt for the ecu. I don't have enough gauges to tell me what the F is going on!!!
Cobra912
1,777
11
39
Wish I was anywhere but here
Mar 22, 2009
  • Mar 22, 2009
I agree. I had to pony up the cash to ditch the FMU, buy some 42lbs 'ers, and a 80mm mass air meter, a Chipmaster Revolution Chip and pay for tune.
I just started my car today and I tell ya - the money was well worth it. runs great!
N
noneck134
24
  • Mar 22, 2009
Vortech V1 SC Trim with 42's, 255 fp, chip, dyno tune and ditched the FMU.
IMO it's all a waste without the dyno.
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 11, 2026
roldy
R
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
M
93 5.0 Microsquirt with Stage 3 trickflow tuning issues
  • marxpreston11
  • Jun 22, 2026
  • 2 3 4
2K
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
