Have a couple of questions concerning tuning on a supercharger?
What should the base timing be with running a 10-13lbs of boost?
I pulled the spout and set it to 8 base, car wouldn't idle unless I adjusted the TB "accufab 75mm" to dump more fuel. But as soon as I put it in gear the car falls on its face. so it running really rich.
Where should the tps be set at on voltage?
Car has a FMU, I'm running a vacum tree right off the Intake Manifold. has a 6:1 fuel ratio disk in it. Is this correct for 38lb injectors?
At idle considering the FMU, how much fuel pressure should I have at Idle?
Currently sitting at 40-42lbs I heard that FMU dump 12 lbs for every lb of boost, don't know if that is true
How much Vaccum shoud be reading on the boost Gauge at Idle?
think its reading 12lbs
what would be the best sequence in tuning?
I don't have a really nice bypass valve, its adjustable with different spring rates I have the the lighest spring in there right now, I ran the vacum line straight from the tree on the intake manifold. however when its hooked up to the inlet pipe, and powerpipe, the car runs like **** barely can't get it to idle right. so I have a it off right now..and I'm not getting all the boost I should be.
Just trying to get the car tuned right...
Please someone give me some advice before I set this car on fire
thanks in advance
thanks in advance
