  • SN95 4.6L Mustang Tech
Supercharger w/o underdrive pulley?
  • Thread starter Thread starter mxracer357
  • Start date Start date Feb 18, 2009
mxracer357
Denver, CO
Feb 18, 2009
  • Feb 18, 2009
I read that you can't use underdrive pullies if you have a supercharger. What is the reason behind this? I was going to get a set of steeda pullies but if they are useless down the road when I get a KB then I don't know if I should waste the money. Does that mean I should hold onto my stock pieces if I get the kit or will a KB system end up replacing those pullies?
D
darkside03gt
851
Sacramento CA
Feb 19, 2009
  • Feb 19, 2009
The reason you cant use underdrives is because of the crank pulley, not so much the other pulleys. Underdrives due just as the name implies they underdrive you accessorys. So if you get a KB or any kind of centri you wont be spinning it as fast so you wont make as much boost and therefore not as much power.
mxracer357
Denver, CO
Feb 19, 2009
  • Feb 19, 2009
That makes sense. Thanks for the info darkside03gt
Flghtmstr1
572
Springfield, PA
Feb 19, 2009
  • Feb 19, 2009
If you use an 8-rib drive system, it won't matter.
D
darkside03gt
851
Sacramento CA
Feb 19, 2009
  • Feb 19, 2009
How? a underdriven 8 rib setup is still underdriven? I dont think there is any underdrive 8 rib setups out there anyway.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Feb 19, 2009
  • Feb 19, 2009
One kit I notice you may get away with using the Steeda pulleys with is the Tork Tech.
The kit utilizes an independent lower pulley for the blower (much like the '03-'04 Cobra), which may allow you to run the U/D pulley in place of the stocker and bolt the new lower pulley to it....much like the OHV supercharger kits do it for the Fox body cars.
But, if you’re set on the KB, then I’m afraid you’re stuck with the stock crank pulley.
Why would you think that?
Flghtmstr1
572
Springfield, PA
Feb 20, 2009
  • Feb 20, 2009
Lol your explanation is EXACTLY why I would think that. If you're using a separate drive system for the supercharger, it doesn't matter what speed the accessory pulleys are spinning. Remember, I'm the guy with the Tork Tech :-D
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Feb 20, 2009
  • Feb 20, 2009
Yes, I know you are....but he's talking about a Kenne Bell. Their system still utilizes a uni-belt drive. The way you made it sound was that all "he" needed to do was upgrade to an 8-rib and his problem would be solved, which in fact isn't true. He would need to upgrade to a Tork Tech.
Did you ever get that thing to the dyno to see what it makes BTW?
Flghtmstr1
572
Springfield, PA
Feb 20, 2009
  • Feb 20, 2009
Not yet, unfortunately. I have a bad exhaust leak because I think I broke the EGR tube while installing the supercharger. As a result, all of my long term fuel trims are very rich. The car still runs pretty well, but I can see a cloud of black smoke behind me when I get on it. It's probably running at around 9:1 AFR lol.
Edit: To keep this thread somewhat on track, I would imagine you could use the other underdrive pulleys with the kit, but no the crank pulley. Still, I'm not sure I would want my water pump underdriven with boost...
T
Engine Removal of Steeda Underdrive pulley
  • THughes
  • Jun 30, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 4, 2026
Dino Dino Bambino
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
M
  • mnky99
  • Sep 5, 2025
mnky99
M
