You will be around 300rwhp if you have a decent exhaust setup and tune, plus you are going to want to get a T-Lok in the rear, and while you are add it probably have 3.55's or 3.73's put in. You will run in the 13's. Which basically will allow you to run with a simple bolt on 99+ GT. Is having that kinda of power and speed nice, yes definately....is it worth putting the money into a V6, that's the choice you will have to make.
Why not get a turbo instead for less the cost and better performance?
You wont find a turbo for less than a supercharger, I don't think anyone makes a turbo kit for the V6 and I assure you it wont be cheaper than a supercharger. The only way is if you can find a used t3/t4 turbo and are able to custom fab EVERYTHING yourself. By that time you could have ordered a supercharger kit, that would take less time to put together and still be running close enough numbers. But if you can get a turbo and want to go fast, it's usually the best.
Are so so sure about that?
You can buy a whole kit ready to bolt on. www.tmaturbo.com will have everything you will need and more.
Well, for a single turbo I'm suprised to find a kit that cheap, but you still will need to buy all the supporting parts along with a more in depth install process.
Now you have me interested. What supporting hardware would you be speaking of? As in fuel pump, injectors, tune, gauges and would you need a k member?
With a Supercharger you still need to buy, fuel pump, fuel injectors and misc other parts, so what's the difference?
And like if you manage to bolt on a Supercharger, you will manage to bolt on this turbo kit. This turbo kit only put out about 4psi and turn the same hp/tq level as the 11psi ProCharger supercharger.
This Turbo kit is as compleate as either Vortech or Procharger and is cheaper.
But no matter what you get, it's ALL in the tune.![]()
upgrades are a lil crazy for the sixer, if you wanna upgrade then all you can do is put a V8, but why do that? Might as well trade in your sixer for an eight... correct? Seems pointless to me. but everybody got opinions![]()
Yes that would be the supporting parts.
Not to be a jerk, but do you work work for these turbo builders or something? Do you even have one? Do you know how to install both a supercharger and a turbo? I ask, because I'm looking at getting either a Vortech Mongoose kit or DSC1Procharger for the GT next year, but if this kit is really something good to consider than I may just go consider it, because I was wanting a HP Twin Turbo to begin with however the price is alittle much.
IMO if you don't need HIGH HP, and you have a V6 this is what I would suggest http://www.rpmoutlet.com/musv6ati.htm. It's TOTALLY complete with injectors, tune etc, more reputable company, much more support from the company and many others that have one or had one and the end result is the same. But it's what ever you decide to choose, turbos are better but superchargers are still as nice.
