Surging and Dying problem over here...
cox_racing
430
Southeast TX
My freakin' car keeps irritating me. Some days are perfect, some are a pain in the booty-hole. My car just has its moments when it wants to die. I can be sitting still at a red light or hallin' gr'ass' and once I press the clutch in or put it in neutral.... it dies....or it just surges.
I've tested everything I can think of: :nonono:
Timing: 12'
TPS: .99
The salt and pepper things are clean
what else can I do? I know my fuel pump is fine....what gives? :shrug:
I ran a code test on it and got codes:
32 = EGR (already replaced the sensor and cyliniod)
44 = Thermactor Air Controll
94 = Thermactor Air Controll
Thanks for your help in advance,
wow...most of the time i've heard of this happening, it's w/ an aftermarket cam. In those instances, some people have had luck using the Idle Air Bypass spacer plate (like $20 and isn't a Ford Part). You can get them from ebay I know. Maybe Yount or someone will see this and help you further. Maybe you've got a vacuum leak somewhere?
