Surging at idle
  • Thread starter Thread starter 1969mach1351
  • Start date Start date Apr 1, 2005
1969mach1351
285
Sacramento, CA
Apr 1, 2005
  • Apr 1, 2005
My engine has almost always had a little surge in the idle since I put in this engine. I have changed carb gaskets and just recently changed the manifold and it still does it. Could there be a vacuum leak in the carb? It’s a 750 Demon that is about 4 years old. It runs perfect when the engine is really cold and really hot. Also if the air temp is above 80* there is no surge. I’ve plugged all other vacuum lines and it still does it. Do I just need to rebuild the carb?
69Rcode_Mach1
1,473
Salt Lake City, Utah
Apr 1, 2005
  • Apr 1, 2005
Buy a vacuum guage they are only $20 and will help you determine the problem. If it's not a vacuum leak then atleast we know that's not the problem.
krash kendall
1,258
Aldergrove, B.C. Canada
Apr 1, 2005
  • Apr 1, 2005
I have the exact problem at similar conditions. When idling at at stoplight in gear it runs fine with an occasional momentary burp as if one cylinder fired with a little more power every3-5 seconds. I've vacuum checked it and ignition checked it and just can't find a solution. It isn't causing any problems what-so-ever, I just expect perfection.
Pbum5
515
Minneapolis, MN
Apr 1, 2005
  • Apr 1, 2005
If it is a vacuum leak
Try spraying some carb cleaner around the carb, intake, etc while it’s running and it might help you find the vacuum leak.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Apr 1, 2005
  • Apr 1, 2005
I've seen such a problem on a vehicle where the power valve was opening due to a drop in vacum. Once the additional fuel was dumped in... the idle and vacum picked up for a second and so the power valve closed. Only to have the idle and vacum drop and cause the power valve to open again.
Could be your power valve, could be a vacum leak.. could also be the wrong power valve to run with your cam.
1969mach1351
285
Sacramento, CA
Apr 1, 2005
  • Apr 1, 2005
My vacuum is about 14 and steady, I don't think it was surging tho last I checked it. My next test was going to be spray carb cleaner around, when i buy some more.
R
Rapid
297
Columbia, SC
Apr 2, 2005
  • Apr 2, 2005
Do you have the right fuel pressure to the carb?
84convertablegt
589
Columbus, OH
Apr 2, 2005
  • Apr 2, 2005
heres a weird story. i had my engine recently rebuilt. they installed a ford factory 4v spacer with the pcv hookup. well i had a crazy surge going on. first thing i did was hook up a vacuum gauge, and it read a steady 15 lbs, no surge. i was very confused. then by just feeling around i managed to stick my pinky finger under the spacer and barely got it to fit down into the intake where the carb mates up. i couldnt believe it. i bought a jegs phenolic carb spacer and a new gasket and the problem was solved. the moral of the story, the vacuum gauge didnt tell me squat! weird isnt it!
2nd Mustang
2,488
Southern California
Apr 2, 2005
  • Apr 2, 2005
The vacuum gauge can help, but is not always the only thing to help trouble shoot. I had many carb related problems, even some minor vacuum leaks, but the vacuum gauge always read a steady 14 inches at idle, even with a brand new carb, it still reads 14 inches due to my cam.
1969mach1351
285
Sacramento, CA
Apr 2, 2005
#10
  • Apr 2, 2005
  • #10
I have the holley blue electric fuel pump with the regulator. I think its set at 6 PSI. Thats about right isn't it?
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Oct 4, 2026
manicmechanic007
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
