• Community Forums
  • Regional Forums and Event Information
surging problem
  • Thread starter Thread starter wicked93
  • Start date Start date Jan 7, 2008
wicked93
5 Year Member
Nov 2, 2003
480
18
28
Winona Ohio
Jan 7, 2008
  • Jan 7, 2008
finally got the 89 notch back up and running but am having some issues. the car is surging real bad the idle will settle in then next thing it is up and down then it will die I have the timing set at 13deg but when I put the timing plug back in the timing only goes up to 15deg. I thought the timing jumped up more than that when the plug was put back in plus it is an aod car so when I put it in gear it will die unless I get on the throttle and keep it running
the combo is very simple so I am getting pissed. The combo is T/F 1 cam, T/F R intake, GT40X heads, I have plugged the hole for the pcv and am just runnuning a vent on the valve cover, I put in new O2 sensers I am tired so later any input on this would be very nice and appreciated thanks
Stangler
A.K.A. Mr. Hankey
1,357
Jan 8, 2008
  • Jan 8, 2008
What type of Cold air intake are you running? Cleaned the Mass air sensor? What's the Fuel pressure?
Nate
wicked93
5 Year Member
Nov 2, 2003
480
18
28
Winona Ohio
Jan 8, 2008
  • Jan 8, 2008
Nate
I am running a C&L 76mm tube and maf with the stock airbox with a K&N filter fuel is set at 39 lbs I believe the maf is clean but will check
Stangler
A.K.A. Mr. Hankey
1,357
Jan 8, 2008
  • Jan 8, 2008
No vacuum leaks right? It should work great, just fire it up and put some miles on it.
Nate
wicked93
5 Year Member
Nov 2, 2003
480
18
28
Winona Ohio
Jan 8, 2008
  • Jan 8, 2008
Nate
I pulled the upper plenum off again to make sure that is what I am thinking as well plus I talked to jon and he was trying to help over the phone and that is what we came up with. I believe that the upper is not going tight because an interference with the fuel rail I think so I have a 1" spacer coming and I am also putting the pcv back on so we will see what happens tomorrow since I have to work tonight
Stangler
A.K.A. Mr. Hankey
1,357
Jan 8, 2008
  • Jan 8, 2008
I've heard of the T/F R having problems clearing some valve covers too. Check those areas as well. Good luck!
:Track:
Nate
wicked93
5 Year Member
Nov 2, 2003
480
18
28
Winona Ohio
Jan 8, 2008
  • Jan 8, 2008
:Track:
Nate
yea that is why the 1" spacer so I know there is clearence plus the extra inch will help bottom end
VR4
vancouver, wa
Jan 10, 2008
  • Jan 10, 2008
put the PCV back to how its supposed to be. thats a vacuum leak.
wicked93
5 Year Member
Nov 2, 2003
480
18
28
Winona Ohio
Jan 11, 2008
  • Jan 11, 2008
i do not see how that could be a leak since everthing is pluged but I did put the pcv system back on plus i have a catch can in the line to catch any oil that always seems to get pulled thru
VR4
vancouver, wa
Jan 11, 2008
#10
  • Jan 11, 2008
  • #10
the pcv valve is plumbed into the intake manifold right? that vacuum from the intake is pulling the oil vapors (and air) out of the crankcase and into the intake to be burned. the other side of the pcv system is the inlet plumbed into the intake tube before the throttle body but after the MAF. thus the air being pulled thru the crankcase has already been metered and is expected my the engine. if you have the nipple on the intake tube capped and a breather filter on the valve cover youre sucking unmetered air thru the pcv valve.
catch can is the way to go. keeps things nice and clean in there.
WaterPog
2,201
Portland, OR
Jan 11, 2008
#11
  • Jan 11, 2008
  • #11
or ditch the PCV completely and run a filter on the valve cover. have to go all the way or none.
I'd also double check your TPS once you're sure you have all the vac leaks handled. Unhook the IAC, set idle roughly with the throttle stop screw a little lower than where you want it. Adjust tps after this and then reconnect the IAC.
86turbo
183
Jan 12, 2008
#12
  • Jan 12, 2008
  • #12
hey man i've run c&l's and so have my buddies.....its been a mixed bag as far as results. You should first make sure you have no vac leaks, set your base timing and idle correctly then clock your maf sensor. No need for a multimeter at first. Just rotate it and see if it improves......we did that to my friends car and mine and it got better. Then we busted out the multimeter and dialed in the signal voltage.
wicked93
5 Year Member
Nov 2, 2003
480
18
28
Winona Ohio
Jan 14, 2008
#13
  • Jan 14, 2008
  • #13
when I had the pcv valve removed what I do is run a boat plug in the back of the manifold, cap the vacum elbow on the throttle body, and run a breather on the valve cover. I found the leak and that was that the upper intake was not sitting flush so I have a 1" spacer now and that resolved alot of it, I rechecked the the bolts the other day and retightened them plus I think the bolts on the T/B was a touch to long so I resolved that I have set my tps and my timing but when I drop it in gear it dies now I am thinking that maybe the problem is the fact that I have the stock tourqe converter so the motor drags it down hard and it is not recovering fast enough and I am not sure if the IAC is working properly or not so I need to check that next thanks alot for the input
wicked93
5 Year Member
Nov 2, 2003
480
18
28
Winona Ohio
Jan 14, 2008
#14
  • Jan 14, 2008
  • #14
I am not running a cold air intake kit so I do not know if that will help but he I am willing to try anything so thanks
86turbo
183
Jan 14, 2008
#15
  • Jan 14, 2008
  • #15
it doesnt matter if you're running a cold air, it makes it worse yes but those c&l's can be finicky
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Electrical F150 ECU in a Foxbody? Idle surge help
  • 93royalblue
  • Sep 10, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
Mustang5L5
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
  • Community Forums
