Suspension advice!
  • Thread starter Thread starter krooxstang
  • Start date Start date Nov 28, 2011
1 of 2 Next Last
K
krooxstang
Wichita, KS
Nov 28, 2011
  • Nov 28, 2011
Ok so I have done main bolt on add ons for my car and now I am getting new gears but now I am wanting to know what suspension stuff I should get and in what order. Lowering kit is my first but then what? I dont plan on supercharging it or anything soon. I want my car to hook up more.....please give me some good advice?
dew22
Banned by Troll
Jan 16, 2003
Tampa
Nov 28, 2011
  • Nov 28, 2011
Not really suspension components, but subframe connectors will help sure up the chassis and allow any suspension parts you get to work properly.
K
krooxstang
Wichita, KS
Nov 28, 2011
  • Nov 28, 2011
so subframe connectors.....what about rear lower control arms and rear upper control arms?? anything else?
03_TrueBlue_GT
810
41
29
Houston, Tx
Nov 28, 2011
  • Nov 28, 2011
Some really good tires, shocks and struts too.
1fun281
438
Atlanta Georgia
Nov 29, 2011
  • Nov 29, 2011
K member and coil over kit, Thats what you want...
Stumbaugh
903
Russellville, Ar
Nov 29, 2011
  • Nov 29, 2011
We really should make a sticky with some of this stuff.
1. Subframe connecters
2. upper and lower control arms
3. Shocks, struts, springs
4. K member and coilovers
Number 2 and 3 can be switched order wise. Regardless, SFC's need to be the 1st thing.
Stumbaugh
903
Russellville, Ar
Nov 29, 2011
  • Nov 29, 2011
BTW:
50% of hooking, is in the weight transfer. When you order some shocks and struts, get some strange 10 way adjustables. I have them on my car and they are awesome.
As far as brand name's for suspension stuff, you are going to get 2 different answers. UPR and Maximum Motorsports
I am a huge fan of UPR. That's what 100% of my suspension consist of. I'm sure Handz will get on here and say that UPR suspension products suck. All I will say about that is, my car hooks in 1st gear from a dig on the street on street tires and makes over 450rwtq.
N8Dogg98
3,872
238
184
MN
Nov 29, 2011
  • Nov 29, 2011
^ I think it depends on what you want out of the car really... some prefer to run auto-x or road courses, while others prefer the 1/8 or 1/4 mile. In this case OP wants to "hook better on the street" and probably can't go wrong with either UPR or MM. I will say though that OP indicated his car doesn't and won't have big HP soon, and IMO MM LCA's and FLSFC's would be preferable to a UPR 4 link setup for a street driven car. It will handle well, not be too harsh, and will hook much better than stock.
Stumbaugh
903
Russellville, Ar
Nov 29, 2011
  • Nov 29, 2011
The only way a Upper and lower control arm set up will be harsh, is if spherical bushings are used. UPR offers their control arms with spherical and poly bushings.
I have been running UPR's stuff since I first got my car and have loved it. If I was building a car to auto cross, I would put MM suspension on it. For everything else, I will stick to UPR.
Sharad
ALWAYS choose the V over the P!!! Wait... what?
Jan 5, 2011
1,562
480
94
Fort Myers, Florida
Nov 30, 2011
#10
  • Nov 30, 2011
  • #10
Yup. UPR for the win! Works really well in a straight line, and can work well in the corners with the right dampeners. (we don't carry konis or bilsteins... yet)
duzy
80
jacksonville fl
Dec 1, 2011
#11
  • Dec 1, 2011
  • #11
for front control arms should i get off set or non off set?
D
Deleted member 38176
Dec 2, 2011
#12
  • Dec 2, 2011
  • #12
Stumbaugh said:
BTW:
Handz is an arrogant moron, his opinions are void.
D
Dec 2, 2011
#13
  • Dec 2, 2011
  • #13
1. full length WELD-IN sub frames
2. shocks/struts
3. control arms
N8Dogg98
3,872
238
184
MN
Dec 2, 2011
#14
  • Dec 2, 2011
  • #14
You may think handz IA a moron but FWIW if I had to make a choice between UPR and Maximum Motorsports, I'd choose MM every time. MM stuff is incredibly high quality and IMO their parts are better for an all around performance perspective (handling, ride quality, and strip performance) .
K
krooxstang
Wichita, KS
Dec 2, 2011
#15
  • Dec 2, 2011
  • #15
well now we are getting somewhere....i already have michelin pilot's...$330 a piece so i think im good on tires but I think im gonna order this weekend. I finally got my wife to let me pull the trigger...then next summer will be a supercharger and that jazz
flstang65
1,484
135
94
SE Georgia
Dec 2, 2011
#16
  • Dec 2, 2011
  • #16
Upper/lower control arms
good shocks/coil overs (strange 10 ways are awesome)
spherical housing bushings
torque boxes
full length sub frame connectors
tubular k member/control arms
offset rack bushings
caster/camber plates
bumpsteer kit
Get your spring rates according to what style driving you are doing.
I use UPR for everything. Great products, prices and service.
Just my .02 Good luck!
D
Dec 2, 2011
#17
  • Dec 2, 2011
  • #17
I was just referring to handz in general
1fun281
438
Atlanta Georgia
Dec 2, 2011
#18
  • Dec 2, 2011
  • #18
And weigh 20 pounds more.. I guess its all opinion i believe in nothing but UPR, im sure MM is nice and top notch, whatever, UPR is just as top notch and quality, but yea whatever works
Stumbaugh
903
Russellville, Ar
Dec 2, 2011
#19
  • Dec 2, 2011
  • #19
I have said it plenty of times, I like MM's stuff, just not for drag racing. Their K member kit's barely weigh less than a factory K member. Same goes with all their other suspension products. If I was building a car strictly for Road racing or auto cross, I would use MM. But for everything else, I will stick to UPR.
You show me one 5 second 1/8th mile car that runs Maximum Motorsports suspension, and I will show you ten 4 second 1/8th mile cars that run UPR suspension. FACT.
N8Dogg98
3,872
238
184
MN
Dec 2, 2011
#20
  • Dec 2, 2011
  • #20
Again I'm not ripping on UPR's products and I think they have a place and a purpose if you intend on building a quarter mile/eighth mile drag car. However, as someone who owns a car that is driven primarily on the street, I don't understand why anyone would choose UPR over MM unless it was due to the price difference.
I've had first hand experiences with 2 very similar cars that had very different suspension setups. One car had MM LCA's and a TA and the other one had a UPR 4-link. There's absolutely no comparison the MM LCA's + TA provide much better control and handling than the UPR 4-link does. There is also less of a chance of experiencing snap oversteer with the MM set up described in the previous sentence due to the corrective nature of the TA combined with the compliant factory UCA's.
Now if all you like to do is launch hard and drive straight by all means buy UPR stuff. In fact that's what is designed for. UPR doesn't even sell Bilstein's, but they do sell strange adjustable shocks... why do you think that is? Could it be because they know they build and sell products that are best suited for drag racers?
As far as weight is concerned, you're right some of UPR's suspension components don't weigh as much. Again, to the drag racer weight is the enemy which is why their components are light... OTOH road racers prefer to have components that are strong enough to handle the rigors of running through an autocross or road course. For me, it is an added comfort knowing that my MM suspension components are over-engineered w/ no compromises. If I ever get in an accident the strength and integrity of these superior components may save my life.
OP, take these comments for what they're worth and make your decision based on the feedback from everyone here. I think there are good arguments for both suspension companies. However, I enjoy driving a well rounded car that can handle and launch well, and still maintain very good road manners... therefore I'll choose MM suspension components every time
1 of 2 Next Last
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
D
97 V6 suspension upgrades
  • Dale1bre
  • Jan 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jan 19, 2026
Buying with a bad motor?
  • djj62478
  • Mar 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 11, 2026
TTSaleen
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
