Suspension guys come in!
Matts89LX5.0
1,314
Long Island, NY
Looking for a good street/drag suspension that hooks. Not looking to spend major money for anything crazy, but the car is not a daily driver either. I already have UPR lower control arms, ET streets, and lakewood 50/50s to go in the rear...now someone share your knowledge to complete this set up...mods are in the sig.
www.teamzmotorsports.net upper control arms
Strange 10 way adj front struts
Strange 10 way adj rear shocks or your 50/50's
Re-enforced TQ boxes
www.teamzmotorsports.net Anti-roll bar
If you run a anti-roll bar you must run springs that are the same rate of both sides, so you could not run the Drag Launch kit.
A stock rear spring, anti roll and a coil over up front is much better then the drag kit.
Yes the rear drivers and passenger sides are different rates.
I used the kit with 70/30's, 50/50's for awhile with good results, now I would recommend the set-up I mentioned above so you an spend the money once and get adjustment.
