  • 2005 - 2009 Specific Tech
Suspension Question - Koni FSD Kit
  • Thread starter Thread starter explrsport
  • Start date Start date Dec 14, 2011
E
explrsport
177
SoCA
Dec 14, 2011
  • Dec 14, 2011
Anybody installed the Koni FSD Kit with struts and shocks for 2005-2012 Mustangs? Pricy at $750-900 delivered and more expensive than a set of Bilsteins.
Koni also sells the same Kit bundled with Eibach lowering springs for a 1.5" drop.
Interested in how they affect the ride over lousy roads; I've seen comments both good and bad. My 2010 GT has stock suspension currently and I don't intend to drop it.
Thanks for any replies.
SheizaSoSay
10
Savannah, GA
Dec 16, 2011
  • Dec 16, 2011
I was interested in those aswell. I called Koni because no mustang owner I met has them. They are NOT designed to be with lowering springs. He said they are fantastic if you don't lower your mustang. Corvette and Mini Cooper owners love them because they usually don't lower their car. If you found a set of those dampers with eibach's paired together FOR A MUSTANG, I would like to see that link. I pillaged through a few forums, mainly vettes and they all seemed to really like them though.
E
explrsport
177
SoCA
Dec 16, 2011
  • Dec 16, 2011
You're 100% correct...very few (if any) Stang owners on the blogs use the FSDs bec of their need to keep the stock height to work well. I've lowered all my older GTs but not my 2010. I spoke with tech support at Koni re their possible bundle of FSDs with Eibach lowering springs...not available (yet) for 2005+ Stangs. Anyway, I ordered the FSD Kit #2100-4064 so we'll see how well they compare to the D-Specs and the Bilstein HDs I've had on past Stangs.
SheizaSoSay
10
Savannah, GA
Dec 16, 2011
  • Dec 16, 2011
Probably gonna be an unfair comparison unless you had the bilsteins or dspecs on ur stang with stock springs. Aftermarket springs are always stiffer except for the bmr's. And they are a hair stiffer. I got this tagged. Looking forward to your results as they will be the only review in existence. Koni has to know that lowering springs are the way to sell these.
E
explrsport
177
SoCA
Dec 16, 2011
  • Dec 16, 2011
Or Koni could design a special FSD model just for lowered Stangs...like they did for the MB SLR McLaren F1...check this link -
http://www.tirerack.com/images/pdf/koni_mclarenF1.pdf
But don't hold your breath!
E
explrsport
177
SoCA
Dec 16, 2011
  • Dec 16, 2011
One other item for anybody checking Koni FSDs shocks & struts for 2005+ Mustangs on the tirerack site...they only list them as available for Coupes, not Verts. I contacted Koni and their tech support stated this is incorrect - they make no distinction between the two models as suitable for this product line.
E
explrsport
177
SoCA
Jan 15, 2012
  • Jan 15, 2012
Finally got the Koni FSD Kit installed and it makes quite a difference - but only if you leave your Mustang at the original ride height. And that's probably a deal killer for most folks on Mustang blogs.
Without a noticeable decrease in handling, they make the ride over bad roads a lot more controlled with less jounce and bounce. It feels like my 19" Brembo wheels and 255 series Pirellis are making the same movements as before - but the chassis above the unsprung weight isn't sending all that motion up the chain.
Past history - I had Bilstein HDs in my lowered 2002 GT and I really enjoyed them. Went to Tokico D-Spec adjustables in my lowered 2005 GT and I never could find the right settings.
My 2010 is my first GT in two ways - my first DD ride and my first with an auto trans. Since I have no plans of lowering it I now believe the Koni FSDs were a great choice to retain handling and smooth out the ever-decreasing quality of the freeways and streets here in SoCA. The set cost about $100 more than a set of Bilstein HDs.
SheizaSoSay
10
Savannah, GA
Jan 16, 2012
  • Jan 16, 2012
Thanks for the follow up. Good info and I'm glad you had experience with other setups too.
Switch from Koni STR.T to Bilstein HD?
  • boostfrk
  • Oct 16, 2020
3K
1996 - 2004 SN95 Mustang -General/Talk- Mar 1, 2021
saltorres077
M
Suspension: Koni STR.T or Other Kit?
  • MattMan02GT
  • Jul 10, 2019
4K
1996 - 2004 SN95 Mustang -General/Talk- Aug 3, 2019
MattMan02GT
M
Better Choice Of These 2 Suspension Kits From Lmr
  • 92Apocalypso
  • Jun 30, 2017
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 1, 2017
Jersey Joe
JCBeaver's 1993 GT Coyote Swap "The Never-Ending Project"
  • JCBeaver
  • Aug 13, 2019
  • 8 9 10
35K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 2, 2020
JCBeaver
New Suspension Project - Convertible - Part 1
  • Robert Arco
  • Aug 26, 2017
3K
2005 - 2014 S-197 Mustang -General/Talk- Sep 24, 2017
Robert Arco
