I don't think the GT takeoffs will; however, I am unsure if the progressive spring rate will make that much of a difference over the OEM V-6 springs.
I PMd shooterm, but he has not responded, so let me do a little research. I am really sorry BTW to hear about the bumper-stumper.
Okay I found the spec doc. Funny thing it says the spec shock absorber for the 2005 are Tokico: It appears at least based on 2006 specs there is no height difference between models - coil rate is better for GT.
So - GT take off spring should work fine. Next element would ensure that spring perch designs are compatable from V-6 to V-8.
Here are the specs for ya:
Type Front: Twin tube gas-pressurized strut. Rear: Twin tube gas-pressurized shock.
Make Tokico
Piston Diameter mm (in)
Front 35 (1.38)
Rear 32 (1.26)
Rod Diameter mm (in)
Front 22 (.87)
Rear 12. (.49)
Suspension-Front:
Coil:design
206 (8.11) Height
145 (5.71) ID
Spring rate N/mm (lb./in.) GT Coupe: 23.9 N/mm (136.5 lb/in). All others: 20.0 N/mm (114.2 lb/in).
Rate at wheel N/mm (lb./in.) GT Coupe: 29.9 N/mm (170.7 lb/in). All others: 26.0 N/mm (148.5 lb/in).
Suspension-Rear:
Coil:design
256 (10.1) Height
62 (2.44) ID
Spring rate N/mm (lb./in.) Convertible: 21.5 N/mm (122.8 lb/in). Coupe: 24.9 N/mm (142.2 lb/in)
Rate at wheel N/mm (lb./in.)Convertible: 25.5 N/mm (145.6 lb/in). Coupe: 29.9 N/mm (170.7 lb/in)
