  • 1994 - 1995 Specific Tech
Suspension
  • Thread starter Thread starter Stevejr
  • Start date Start date Dec 30, 2008
Stevejr
63
Humboldt Tn
Dec 30, 2008
  • Dec 30, 2008
2 questions#1 Do these cars always bottom out so easy? #2 I have a poping in the left front(sounds like anyways) when i hit the brakes or a bump or turn the steering wheel I have had someone push it up and down turn left and right while i laid under it and watched no popin any ideas? Thanks for your opinion.
I
inphiniti
412
Providence, RI
Dec 30, 2008
  • Dec 30, 2008
is ur car lowered? if so, then depending on how low yeah... im lowered 2 inchs and dont bottom out often, but then again i baby it when going into inclined driveways, speedbumps, etc etc...
as for the popping idea, not 100% sure... those may be ur ball joints... you may be in need of some. if your vehicle is lowered, look into the steeda x2 ball joints and the steeda bumpsteer kit... could help fix any problem you got goin on...
drakesdad
961
Oregon OHIO
Dec 31, 2008
  • Dec 31, 2008
Steve, one of the other 95's I had had similar problems...it had stock suspension but as you said, it road fine until I hit a bump and turned......what I found is that there was a break in the last spring at the bottom..it was on both sides of the car too....it was hard to see because of teh rubber at the bottom....just a idea to check.
Stevejr
63
Humboldt Tn
Dec 31, 2008
  • Dec 31, 2008
No my car is not lowered. I think I found the popping After I looked and looked I have had it on the lift 3 times just for the popping. I think what it was is the bushings where the sway bar attaches to the frame. As for the bottomin out She is very sensitive to weight she will bottom out when im alone but she does it more when i have my suitcase in the trunk or when I have a large passenger. Does anyone know are 6 cly rear springs the same? Cause i have a donor car.
hollywoodstang
1,095
Dec 31, 2008
  • Dec 31, 2008
My 96 did that and found out that it was sway bar bushing and ball joint both at 60k...
I have my 95 slammed with saleen springs and x2 ball joint and i bottom out often since my car is convertible and have that underbrace thing.
But yes check the ball joint and sway bar busings.
Stevejr
63
Humboldt Tn
Dec 31, 2008
  • Dec 31, 2008
Ball joints are good checked today.
9
95_5.0@15
24
  • Jan 1, 2009
title of this thread
did anyone notice that the name of this thread is suspenison
drakesdad
961
Oregon OHIO
Jan 1, 2009
  • Jan 1, 2009
Yeah, I saw that, but I have been guilty of speed typing and typo's ......
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Jan 1, 2009
  • Jan 1, 2009
Title fixed.
Posted via Mobile Device
T
tderrick
312
Jan 5, 2009
#10
  • Jan 5, 2009
  • #10
How 'bout a blown strut?
Venom351R
4,548
41
98
MAINE
Jan 6, 2009
#11
  • Jan 6, 2009
  • #11
The popping could be your control arm
MustangLX-5.0
856
Lehigh Acres Fla.
Jan 6, 2009
#12
  • Jan 6, 2009
  • #12
Does it shake while driving? Besides the popping,any other noises? Is it just going over bumps and turning?
Could very possibly be an inner tie-rod.How is your steering? Is it tight? Any loose spots? Does it turn on a dime? Meaning,does it turn with the slightest movement of the wheel?
You might also want to check the tightness of your steering rack.The metal sleeves that the mounting bolts pass through will eventually start shifting when the bushings wear.This creates a loud creak or pop noise.Most noticable turning a corner at moderate speeds or shifting the wheel back and forth while sitting still ( usually once or twice after the car sat a couple hours).
Could very well be a strut issue also.But don't quote me on that.Im not positive.I'm still dealing with some issues myself.
Stevejr
63
Humboldt Tn
Jan 9, 2009
#13
  • Jan 9, 2009
  • #13
One problem solved the popping is gone, It was the bushins that attach the front sway bar to the frame. The bottoming out is inn the rear only I have already replaced the shocks still does it, is this typical or are my springs just wore out?
F
fordtech28
312
Riverside Cali.
Jan 10, 2009
#14
  • Jan 10, 2009
  • #14
Man this is a pain to figure out I have the exact same issue on my cobra I checked everything theres no play on the ball joints or the outer tie rods and everything that has to do with the suspension .I found something interesting while changing my oil the other day out of curosity I tested the steering shaft for play and it had some play more than Im used to seeing and the rack and pinion moved quite a bit too thats my next check point even though I had checked it before but I checked it this time while it was on the ramps last time I jacked up one side.Funny you mention the strut too because I had a hard time setting my camber on the left side where I hear the poping it wouldnt stay I kept moving the strut around from the strut mount.Hopefully I get this fixed too .
M
MORDENENOUGH
#15
  • Jan 30, 2009
  • #15
My car does this too, but its lowered slightly. I've got BBK lowering springs and Tokicos so if I hit a large crack in the road with both rear wheels it bottoms out every time. I bought a Maximum Motorsports bump stop that is shorter and softer to cushion the blow. I don't know how well it works yet though because my car is stored for the long cold winter.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
D
Progress Thread Today in the shed........
  • Don7Up
  • May 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
LILCBRA
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
