Sve High Performance Fuel System
So help me figure out the best method to go about this. My stock fuel lines and rail is able to support the power I'm wanting to make. I need more pump and bigger injectors. I'll probably go 60# injectors to give me a little room to grow down the road. I'm thinking two options...
Option #1:
- Drop in an Aeromotive 340lph in tank fuel pump.
- Order the "tuner" Vortech kit that omits the T-Rex boost a pump, because the 340 should be enough, right?
http://www.andersonfordmotorsport.c...it-with-a-free-power-pipe-fits-86-93-mustang/
- Does an aftermarket FPR, like my Kirban, increase fuel pressure with boost?
- Is there anything else I would need because I bought the "tuner" Vortech kit? I'm assuming they make the tuner kit for people who already have their fuel system up to par. An intake pipe is omitted but if I order from Anderson they throw in a free power pipe. Can I achieve the tuning that I need through an SCT dyno tune?
Option #2:
- Order the standard Vortech V3-Si kit and run the T-Rex boost a pump with my current 255lph in tank.
For simplicity, I like the idea of running a single in tank pump, which is why I would like to go with option #1. Plus the "tuner kit" is cheaper.
Another question, can I send my 75mm Pro-M bullet MAF in to be recalibrated for the supercharger and bigger injectors?
Tuner kit will include everything you need minus the fuel/tuning. Every bracket, pipe, hose, tube you need is included. If you want to save a few dollars go with the UPR boost pipe over the Anderson piece. Personally the T rex is the way I have gone in the past but I've seen several cars more recently running a single 340 pump without issue. It's a personal preference at this point you'll be fine either way. Your current fpr will work for you without issue and a competent tuner can burn an SCT chip for you on the dyno.
Have you got pricing on the V3 Si tuner kit yet? If you haven't ordered give me a shot a quoting you on it, shoot me a PM
Awesome, thanks for the info. I thought that post was going to get lost and I was going to have to start another thread on the subject lol. Best deal I've seen on the tuner kit is from Anderson, power pipe included, $2,999 (link in above post). I will definitely send you a PM when the time comes, I haven't got my taxes done yet.....you know how that goes $$$.
Reactions: 1 user
