Swapping Cluster, Have A Question
Micheal Nadeau
258
32
49
Savannah, GA
Has anyone successfully swapped a 90-93 into an 87-89? If so, care to pm me with any issues you ran into. This would appear to be straight forward, but comparing the description of wires from one to the other, some things don't match up. I swapped a 140 from a different cluster and dropped it into my 89 cluster, but lost the calibration. So I it doesn't register speed until almost 10 miles an hr, is off by 7 mph (ex 20 is actually 27) at that point and slowly closes the gap until about 70, then its off the other direction. I have the cluster and would like to use it. The rest of my dash is 90-93.
Do the 90-93 cars not have a low fuel light anywhere? Also, if anyone has swapped clusters, any concerns with the airbag light pin out? I laid both of them and traced the "boards" on each so the wording matched from one cluster to the next. It would appear that this task is daunting due to the only write up showing the pin outs uses different words for the same pin. Will be pinning it out in the morning. Will update when done.
I've done this. Seems I had to replace the plastic shroud that goes around it, or else it left a gap or something. Only reason I did it was because i bought a cluster off ebay and took so long to put it in that I couldnt return it.. If i had to do it all over I would have just resold it. There's a google picture somewhere of what wires need to be re-pined where. I dont believe I have a low fuel light. Air bag pin didnt have to do anything with this..
