JT you have poly stuff right? Did it make your ride rougher talked to the guy that owns the body shop where my car goes he said after he put poly stuff on his camero it made it rougher but his is a drag car so i don't know if that makes a difference
I've got poly bushings all throughout my Stang's suspension - I don't have a single rubber bushing left. It does make your ride rougher, because all the bushings are stiffer. But, that's a good thing - they have less give now, so the suspension moves the way it's supposed to. There isn't any play in my steering wheel anymore - the Stang goes exactly where I want it to go.MysteryMachine said:JT you have poly stuff right? Did it make your ride rougher talked to the guy that owns the body shop where my car goes he said after he put poly stuff on his camero it made it rougher but his is a drag car so i don't know if that makes a difference
You already got great replies, but I will chime in anyhow. I dont see poly as all that brutal - pure perspective here. In my first dabbling on suspensions a long time ago, I put Delrin on the double-wishbone front suspension of a Euro car I have. Now that was pretty brutal. Poly is much less brutal, so it does not bother me.MysteryMachine said:JT you have poly stuff right? Did it make your ride rougher talked to the guy that owns the body shop where my car goes he said after he put poly stuff on his camero it made it rougher but his is a drag car so i don't know if that makes a difference
. Or do the MFE alignment (yourself).
