  • 1994 - 1995 Specific Tech
sway bar
  • Thread starter Thread starter will_95gt
  • Start date Start date Oct 24, 2005
1 of 2 Next Last
will_95gt
298
Austin, TX
Oct 24, 2005
  • Oct 24, 2005
OK my sway bar broke (don't ask how the hell that happened cuz i have no clue)
So, after leaving it hanging off on one side for a good month or 3 i just now took it off. I figure, its not like it was doing any good at all or even working. Now, this is where it gets hairy. My parents see me taking a large bar out from under my car and throwing it in the garage... no matter how much i convice them that i can still drive 6 streets down to school and back without the car falling apart because i took off the sway bar... they are still freaking out and are now saying i can't drive untill i buy a new one! crapola
soooooo, how unsafe is driving without a sway bar. I realize i'm not going to spin out of control going 30 to school and back but what do u guys think? How urgent is it to get a new one. I don't plan on highway driving or anything for a while but do u guys think just residential stuff is fine for now? Also, i found a used cobra one for 80 bucks. IS that a fairly good deal?
Thanks guys
BlackVert
5,589
9
98
Bethesda, MD
Oct 24, 2005
  • Oct 24, 2005
on our cars, a broken sway bar is very common. i had mine off for a year and a half. some people who have aftermarket control arms take them off on purpose.
if you have stock control arms, a sway bar will help keep them where they should be and you should definately get a new sway bar, but you can go a few weeks without worrying, just drive gently.
RFMustangGT
294
Knoxville,TN
Oct 25, 2005
  • Oct 25, 2005
what does a broke sway bar feel like?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Oct 25, 2005
  • Oct 25, 2005
front or rear?
RFMustangGT
294
Knoxville,TN
Oct 25, 2005
  • Oct 25, 2005
both
will_95gt
298
Austin, TX
Oct 26, 2005
  • Oct 26, 2005
well my rear sway bar is the one that was broken. I didn't feel a difference in the way it drove although it made a hiddeous racket.
will_95gt
298
Austin, TX
Oct 29, 2005
  • Oct 29, 2005
This guy told me he could weld mine as good as new... is this ill advised? Are the stock sway bars steel?
T
TMC
1,426
Chicago
Oct 29, 2005
  • Oct 29, 2005
don't weld it...it's a spring and by welding it you will change it's rate and make it more brittle.
Tell you're parents to climb under a v6 stang and look for that silly bar, they won't find one.
Labora
1,855
26
69
Dallas, Texas
Oct 30, 2005
  • Oct 30, 2005
Common problem. I haven't driven with my rear bar for over 8 months. (and from what I've heard Cobra's even have a softer rear spring rate then GT's (big sway bar and softer springs)) so you shouldn't have any problems.
It is perfectly safe. I've had my car up to 120ish, been to the 1/4 mile track, and done a autox without it. If you can get a 94-95 Cobra bar for 80$ jump on it thou sounds like a good deal (if it also isn't cracked or broken!)
chrismillion
20+ Year Stangneter
Mar 4, 2004
259
#10
  • Oct 30, 2005
  • #10
correction
there is a sway bar under V-6 stangs. when mine broke on my 95GT, i took the one off my 95 V-6 and put it on.
T
TMC
1,426
Chicago
Oct 30, 2005
#11
  • Oct 30, 2005
  • #11
Hmmm...learn something new everyday.
CManT1914
3,172
Killeen, Texas
Oct 30, 2005
#12
  • Oct 30, 2005
  • #12
When my sway bar broke the rear just felt a little more squirrely in the twisties. But that was going like 80mph on back roads, not 15 around residential corners. It's not that big of a deal really. I did end up buying an Eibach set, but that's just because I'm picky.
However........... losing the FRONT sway bar can be bad. You will lose a lot of cornering ability. The only good part of doing that is it allows more weight transfer to the rear wheels = better launches.
9
95cobradude
Banned
Apr 1, 2005
194
long island, ny
Nov 3, 2005
#13
  • Nov 3, 2005
  • #13
the rear cobra bar is the fix for that but the front cobra bars on the 94-95 aint worth a lick.
BlackVert
5,589
9
98
Bethesda, MD
Nov 3, 2005
#14
  • Nov 3, 2005
  • #14
yeah, i heard that the cobra sway bars are much beefier than stock gt sway bars.
FORCED2DV8
458
Grand Rapids MI
Nov 3, 2005
#15
  • Nov 3, 2005
  • #15
I think the rest of them covered it.
will_95gt
298
Austin, TX
Nov 4, 2005
#16
  • Nov 4, 2005
  • #16
welllll, i had my broken one welded... the guy said he'd weld it for free so i figured why not. It had broke right at a bracket so naturally that bracket is probably lying in some ditch in the mid-eastern US. Would it be worth it to order another bracket and put in the welded one? I don't see how it would make a difference, it seems to be as good as new. And what size brackets are on our cars? thanks guys
W
whitesnake1994
70
Shelby Township, MI
Nov 4, 2005
#17
  • Nov 4, 2005
  • #17
dumb question...where is the front sway bar??
CManT1914
3,172
Killeen, Texas
Nov 4, 2005
#18
  • Nov 4, 2005
  • #18
It attaches with the help of some end-links to the a-arms IIRC. You can't miss it, it's a big bar in the shape of a C.
Zero Signal
2,633
Tucson, AZ
Nov 4, 2005
#19
  • Nov 4, 2005
  • #19
Our stock setup in the rear sucks. It's not even mounted right. It has no guide bushings. With the lateral play in our 4-link rear, the stock bar just snaps under just the right loading conditions. I broke two of them, and now I don't have one. When I get around to getting a new one, it's going to be a real swaybar from MM or equivalent.
C
ccoypat
28
#20
  • Nov 4, 2005
  • #20
I had my rear sway bar break. I had it welded and it didn't last a month. I went to the dealer and ordered a cobra rear sway bar for about $130. I haven't had any problems since.
1 of 2 Next Last
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
F
Sway Bar Endlinks
  • Fri Guy
  • Jun 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 30, 2025
Fri Guy
F
Rear sway bar popped off
  • Creomod
  • Jan 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 16, 2025
limp
J
Traction Whipple stage 2
  • Jimmy koutoulas
  • Aug 2, 2025
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Aug 12, 2025
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
