I finally finished my front suspension rebuild. I started this rebuild in the spring, but apparently the springs that I bought from a guy here in the classifieds were not for my car. The springs were too short so I had to buy some of the 1" spacers. When I initially put the springs on and took the car off the jack stands and noticed that it was way too low, I ordered the spacers and just got to install them today. Anyway, I got the spacers on and the stance is right now, but I am still not real sure about the springs, I think maybe they are 6 cyl. springs because the car almost bounces a little when I push down on the front. When I went to fit the 1" sway bar, the first thing I noticed was the brackets that hold it to th frame had the holes too wide, but I got it on, even though the bolts are a little crooked looking, it is tight. When I went to attatch the end links the bar seems like it is too short where it attatches to the end links. I had to adjust my strut rods as far as I could to move the lower control arm towards the from of the car. It still is not straight up and down, but I was able to get the bolt started and tightened. I drove the car around the block and it seemed a lot better than it was before, but I am concerned a little about the strut rod being maxed out. On the front where it is double nut with the castle nut and cotter pin, the castle nut and the 1" nut are about an inch apart. Has anyone else ran in to this problem when replacing the front suspension. Will I be OK? I replaced lower control arms, rebuilt uppers, rubber strut rod bushings, shelby drop, roller perches, new springs, KYB GR2's, and 1" sway bar. Thanks in advance, and sorry for the long post...
Ryan
Ryan
