  • SN95 4.6L Mustang Tech
Sway Bars
  • Thread starter Thread starter Disturbed One
  • Start date Start date Nov 28, 2005
D
Disturbed One
191
  • Nov 28, 2005
I've been debating on lowering my car, which is a 97GT, and trying to figure out the best combo to handle DD and some once in the blue moon 1/4 mile track. I've looked at the Bullitt suspension which would drop the car an 1" replace the shocks and struts and sway bars. Does the sway bars from stock make a big difference? I've also been told to just get a solid cobra rear sway bar?
If the sway bars don't make a big difference then mine stock then what would be a good combo for 1-1.5" drop and make it handle very well without going too expensive?
KronicRacer
502
puttering around Ft Lauderdale, FL
Nov 28, 2005
  • Nov 28, 2005
get a steeda adjustable rear sway bar
http://www.stangsuspension.com/store/comersus_viewitem.asp?idproduct=60
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Nov 28, 2005
  • Nov 28, 2005
I'm interested in this as well. I'm looking to switch K-members, and upon converting to coil overs, I'm going to see if I can't figure out a setup that will allow me to maintain decent handling, and thus, sway bars is an item on the list.
I seen one of the vendors over at the corral is selling both from and rear Bullit sway bars for 69.99 brand new in a package together. How much the shipping is, and how well these pieces handle over the stock GT sway bars, I have no clue.
tomustang
Psychotic Member
3,434
McLean Hospital
Nov 28, 2005
  • Nov 28, 2005
Cobra spec rear swaybar, MM swaybar bushings and endlinks in the front. You don't need to replace the front bar, in fact upgrading to a thicker bar will cause more understeer, but you can go to a Adjustable Rear one, stiffer rear springs yada yada to compensate for it, you know how I stand on the K member
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Monday at 4:00 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Today at 8:51 AM
Rdub6
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
G
Front Sway bar HELP
  • Grabberblueguy77
  • May 28, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 28, 2025
gkomo
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
