  • SN95 4.6L Mustang Tech
Switched 12v ignition source needed
  • Thread starter Thread starter 00gtslow
  • Start date Start date Jul 1, 2006
00gtslow
9
  • Jul 1, 2006
Ok i need a switched 12v ignition source for my nitrous system. I spliced into one that had 12v when the key was on and 0v when the key was off. Then when i armed the system my windshield washer pumped kicked on. So whenever i arm it the windshield gets sprayed. Nice little surprise i got. I spliced in and made a Y connection with a butt splice splice with 2 wires in one end and one on the other. from the butt splice it goes Y's out again into 3 switches. Heater, Arm, and Purge. Can anyone give me a hint on whats goin on and a suggestion for a switched 12v power source. Thanks much.
D
dannyboy1999
147
Crossville, TN
Jul 1, 2006
  • Jul 1, 2006
Could use the headlight switch its a 12v power and ground, every time you pull the headlight switch you would arm then
00gtslow
9
  • Jul 1, 2006
Im still gonna use a toggle switch but i need a wire to splice into to get 12v when the key is on. I think the windshield washer pump is turning on because im providing a ground every time i turn the switch on. Its one of those light up toggle switches that requires a ground wire to turn on the light. Im gonna try disconnecting that ground wire from the switch and see what happens. But if that doesnt work i dont know what to do and im gonna be afraid to tap into any other wires for fear of turning on something else along with the nitrous. I might just keep it simple and take the power wire for the cigarette lighter and use that. I actually made a lighter that would turn on the nitrous system when you pushed it in but wouldnt heat up the coil. I forgot where i put it but it was pretty sweet, just got bored at work one day and when you work at a parts store u have everything you need. If anybody is interested i might try and make another one and post a write up. It took me a while to figure it out and make it work right.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jul 1, 2006
  • Jul 1, 2006
see if you can tap into a wire under the dash in the fuse box, i got a power wire for my aftermarker cd player from the stock fuse for the 460 amps
00gtslow
9
  • Jul 1, 2006
Thanks Urban Ill prolly look into that when i get home. But since those lighted switches provide a ground im still in fear of turning something else on at the same time so ill prolly just steal the power wire from the cigarette lighter or just remove the ground wires on the switches if that cures the windshield washer problem.
D
dannyboy1999
147
Crossville, TN
Jul 1, 2006
  • Jul 1, 2006
Also look into you ciggerette lighter wireing they should be 12v too and wont set anything off
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
Jul 1, 2006
  • Jul 1, 2006
if youre gonna use a "ARM" switch between the power source and the nitrous, why not just go straight from the battery?
if youre worried about arming it on accident, get one of those safety switches from autozone, the ones with the flip cover and toggle under it.
G
Resolved Please help! (starting issue)
  • Ghoste
  • May 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2025
Ghoste
G
A
Resolved Fuel Pump issue - test port jumped comes on (87 LX)
  • afjLX
  • Nov 16, 2024
2K
Fox 5.0 Mustang Tech Nov 26, 2024
afjLX
A
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
J
2000 Ford Mustang GT No Crank No Start please help
  • Jowen216
  • Jun 5, 2024
3K
SN95 4.6L Mustang Tech Jul 5, 2024
Jowen216
J
T
Electrical Fox will crank but won’t prime HELPP
  • Tortoler0
  • Jul 1, 2024
3K
Fox 5.0 Mustang Tech Feb 10, 2025
bhowe2
