Would you guys replace the booster in this situation.
Cobra brakes (99+ front calipers). Running an 95 V6 used Booster with a brand new 93 cobra MC.
I don't drive often, so i can't remember if it's been slowly degrading over time. Basically, i hear a light hiss when i press the pedal and sometimes if i jump on the brakes fast while pushing in the clutch, it stalls the car out.
Also, i notice at higher RPM's, the brakes are a little harder than at low RPM's. Car still stops nicely, but the pedal is a little inconsistent.
With the engine off, the pedal pumps up hard as a rock. With my foot on the brake, i start the car and the pedal sinks a bit as it gets vacuum.
I also notice playing with the 1-way valve on the booster does affect how it feels. It's almost like it leaks slightly. Can i pick this part up separate somewhere?
So what would you guys do? Should I just order up a new 93 cobra booster over the winter? Brakes are important to me, and i should have just installed a brand new booster from the beginning.
