Systemax Ii Questions
Got it, though I have to say....don't expect huge gains. The Cobra intake is getting near maxed, but not so much that another intake is going to provide a vast power improvement. You may actually end up picking up some power up top, but at the expense of the low end of your torque curve. Also, the Pro-M 80 is waaaay overkill for your horsepower levels, so unless you've got some form of forced induction in the future, you'd probably be better served with their very popular 75mm bullet.
I'm glad someone made a counter argument. Consensus locally is systemax and power pipe with maf in fender well. I think 80mm pro m is only way to do that. I didn't think you could really go "too big" on maf, but I wouldn't be on this forum if I knew everything.
Reactions: A5literMan
Its good way to eat up $1,000....but I don't think you're going to be ultra satisfied with the gains.
The TFS 170's are great heads, but they aren't deep breathers. You're never going to make big horsepower with them in a N/A set up. If it were me, I'd concentrate on keeping a nice fat torque curve. The Systemax II is going to increase volume, but at the expense of velocity. That'll translate to eating up a measurable amount of bottom end over the Cobra.....no two ways about it. And since the heads don't rival the flow potential of that intake, you won't realize major top end gains with it either. The power pipe/ 80mm MAF combo is a nice pairing, but again because you don't have the heads, can, or the cubes for it, you're not going to realize the potential of their gains either.
Go ahead and buy the intake, pipe and MAF if you've got plans later on of adding a better set of heads, cubes, forced induction, etc....but otherwise, I think it's money wasted.
FWIW, I'm running a TFS Track heat (equivalent to the Systemax II) the Anderson Power Pipe and 80MM MAF air on my engine too. I've got a pretty substantially ported set of GT40X heads (which are probably equivalent to a set of out of the box TFS 170's) backing a higher compression 331ci and a healthier XE274HR camshaft (equivalent to a TFS Stage 2) and even I wasn't utilizing the benefits of that intake set up.
Thank goodness the Vortech is in the process of being bolted on as we speak. ;)
I will sly you disagree with Gearbanger's advise. While you have heard good advise on the pipe/MAF,intake...it will probably make the car slightly quicker. You won't feel a difference on the street that much. At the track??..yes. Probably a couple tenths or so better. If you're going to add cubes,forced induction,etc then you're probably going to need different parts anyway. It really depends on your future plans. IMO I wouldn't really buy those parts unless I knew exactly the future build(I did buy those exact parts for my planned 302 build-but had more head and cam). The 80mm MAF would be fine and the power pipe(unless going blower later-the n/a pipe is different) is more than enough. The intake is a good choice. You will slightly loose some bottom end(under 2500-3000rpm) but the middle rpm and up will be increased. Also you wouldn't miss that torque much. Is it worth the 1000$ for the "bang for the buck cost"? Probably not...
I'd just add nitrous lol.
Reactions: deathb4dismount
