T-45 T/O Bearing issue
Hello to all.
I have been a long time lurker, but decided to register in the hopes that someone would be able to help me with my current problem. The problem is that I have gone through 4 t/o bearings in the last 20k miles. I am looking for possible reasons for this impressive failure rate. I do not ride the clutch pedal, so that is out. But other than that, all suggestions are welcome.
Thanks in advance,
-J-
Having same problem here also with 96 cobra t/o bearing 8000 miles and it's squeeking. Nobody seems to be able to pinpoint the problem. I'm lost here myself, and hate changing them,specially with longtube headers. Oh well hope we get an answer someday :shrug:
hey, great post and article, but is this such a concern that it is doing damage, because I had a performance shop look at mine and they just said no need to go replacing the clutch again, all those parts that you mentioned. but do you think that could do damage to a transmission or something, because i just dont want to go wasting money on another clutch and throwout bearing yada yada yada, id rather get some 410 gears :D what do you think? your final thoughts ? lol
Put in a new clutch and TOB at 40K miles or so and it started making noise after about 500 miles on and off. Put on a Firewall adjuster and it seemed to help for awhile, but it is acting up again now at about 50 k miles. Drives me insane.
Eventutally you can trash the input shaft on the tranny and thus, ruin the tranny.
Hello to all,
This is an update and a special thanks to TXSnakeCharmer. My t/o bearing problem has not been a squealing issue, but a popping one. My first t/o went out with that standard squeal at 30k. The next started popping 5k later. New t/o bearing and the popping went away. However, it liked to come back at 3k to 5k intervals. Needless to say, it began to get a little annoying. This last time it started, I started this thread. That is the history.
By luck I stumbled over TXSnakeCharmer's site. I was looking at his Velocity Tube set-up and saw his link for his T-45 fix. He discribed my problem exactly and his fix for it. I figured that just changing out the t/o bearing was not solving the problem so why not try someting different. I already have the transmission out, (at least the shop did) what is another $40 in parts. So I replace the clutch release arm, pivot bolt, and t/o bearing. Added a little hi-temp grease and prayed that this would solve my problem. I did notice that the old release arm and pivot bolt were pretty worn. That has helped my faith that this might fix my problem. So far, so good. Put a thousand miles on her since the change. Keeping my fingers crossed.
Anyway, thank you TxSnakeCharmer. That site of yours is truely appreciated. :nice:
-J-
P.S. Sorry for the long post
