You can use the stock z-bar setup with both the early and late model belhousings. In your situation, the linkage goes where it used to go-- all the parts are the same (the pusher fork, fulcrum, and throwout bearing). I used the z-bar with the t5 bell by spacing the fulcrum 3/4". It works just like the original, which never worked very well to begin with (my car is a hodge podge though). I would recommend a hydraulic setup if you had the t5 bell and fork.
