  • 1994 - 1995 Specific Tech
t-stat question
  • Thread starter Thread starter RFMustangGT
  • Start date Start date Dec 22, 2005
RFMustangGT
294
Knoxville,TN
Dec 22, 2005
  • Dec 22, 2005
would a 160* t-stat cause pinging? I've just put a set of thumper e7s on, change the fuel filter, new act sensor, cleaned mass air meter and it still pings soo bad. also would bumping the fuel presure up help? right now I think it's already too high. I have it set at around 38psi with the vacume line off. thanks ahead of time.
a_k
170
Saratoga NY
Dec 22, 2005
  • Dec 22, 2005
i don't think a 160 thermostat will cause pinning but its deff to low. Most people go with a 180, it seems to work good for me.
HISSIN50
34
129
Dec 22, 2005
  • Dec 22, 2005
Well, what temps do you run at?
The colder the operating temps, the less likely detonation or preignition are.
What is your timing set at? You set your FP to the stock setting. A slight bump should not hurt anything.
Good luck.
RFMustangGT
294
Knoxville,TN
Dec 22, 2005
  • Dec 22, 2005
right now it does not go past R on the guage. timing I don't think is past 10*. and the FP is set around 38 with vacum off.
a_k
170
Saratoga NY
Dec 22, 2005
  • Dec 22, 2005
i'd get an autometer water temp gauge they are pretty cheap and so much better. My stock one was reading at the L and the autometer says everything is all good
bill302
2,131
alabama,gadsden
Dec 22, 2005
  • Dec 22, 2005
10*to14* timing is good.has your problem started with the cold weather. a motor running too cool will cause oil and carbon build up, i'd install at least a 180* thermostat.and run some sea foam thru fuel system and intake system stock setting for fuel pressure is 35-40 psi.
Black95GTS
1,644
Marlborough, MA
Dec 23, 2005
  • Dec 23, 2005
I would try removing that Diabo Chip, setting the timing to 10, then taking it for a spin. If thats an off the shelf chip, then its basically doing the electronic version of twisting the dizzy. The e7's aren't very timing friendly. I used to run a JET chip and it would cause pinging if I used gas below 91 grade octane.
I think 160 degrees is too low as well but I have no proof other then what I've read and talked about, so take that as you will.
Adam
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Dec 23, 2005
  • Dec 23, 2005
The 160 stat isn't that great for our cars. The coolant will cycle way too much.
With a bumped timing running premium fuel is required. Just for a test put some octane booster in the tank with 93.
RFMustangGT
294
Knoxville,TN
Dec 23, 2005
  • Dec 23, 2005
I think in the next day or so I'll go and put the 180 stat in and bump up the FP. I already run 93 as the chip requires it.
bill302
2,131
alabama,gadsden
Dec 23, 2005
#10
  • Dec 23, 2005
  • #10
run some sea foam thru system.
HISSIN50
34
129
Dec 23, 2005
#11
  • Dec 23, 2005
  • #11
Good stuff on here. Another thought:
If you have Mike's heads, have you asked him for tips?
Good luck.
RFMustangGT
294
Knoxville,TN
Dec 23, 2005
#12
  • Dec 23, 2005
  • #12
no but I'm writing an e-mail right now.
crazyhorsegt
51
tn
Dec 25, 2005
#13
  • Dec 25, 2005
  • #13
like a few others said, i put a 160 t-stat in my gt vert, it wasnt right, so i put the 180 back in, it's just fine now, just my.02
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Dec 25, 2005
#14
  • Dec 25, 2005
  • #14
Is it pinging at part throttle accel or WOT?????
RFMustangGT
294
Knoxville,TN
Dec 25, 2005
#15
  • Dec 25, 2005
  • #15
it's doing it at 3/4 and WOT.
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
Engine Popping noise in the intake. Frustrated still.
  • esteban31065
  • Apr 6, 2025
Fox 5.0 Mustang Tech May 23, 2025
gkomo
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
  • dan50
  • Jul 18, 2026
dan50
