t-stat question
would a 160* t-stat cause pinging? I've just put a set of thumper e7s on, change the fuel filter, new act sensor, cleaned mass air meter and it still pings soo bad. also would bumping the fuel presure up help? right now I think it's already too high. I have it set at around 38psi with the vacume line off. thanks ahead of time.
Well, what temps do you run at?
The colder the operating temps, the less likely detonation or preignition are.
What is your timing set at? You set your FP to the stock setting. A slight bump should not hurt anything.
Good luck.
10*to14* timing is good.has your problem started with the cold weather. a motor running too cool will cause oil and carbon build up, i'd install at least a 180* thermostat.and run some sea foam thru fuel system and intake system stock setting for fuel pressure is 35-40 psi.
I would try removing that Diabo Chip, setting the timing to 10, then taking it for a spin. If thats an off the shelf chip, then its basically doing the electronic version of twisting the dizzy. The e7's aren't very timing friendly. I used to run a JET chip and it would cause pinging if I used gas below 91 grade octane.
I think 160 degrees is too low as well but I have no proof other then what I've read and talked about, so take that as you will.
Adam
