i have a friend that has an 86 turbocoupe. he just bought a t04e hybrid from "xs power" he is having problems with it because he thought it was a direct bolt on and i've been helping him with things that he needs to change. i'm not to sharp on turbos so i was wondering if someone with experience could help clue us in to what all needs to be done for the t3 to t04e hybrid conversion. if someone knows where a good write up of it is i would appreciate the help.
a few questions we have about it:
1) is the t04e hybrid oil cooled only? the stock was oil and water
2) the oil feed and return lines are located horizontally from each other when bolted up as compared to vertically is this ok?
3) has anyone dealt with xs power? and are they reputable?
4)should the t04e be a direct bolt on?
5) is there a better (as in bolt on friendly) t04e out there rather than the one offered by xs power?
6)nothing else seems to fit besides the turbo to the exhaust manifold. all the stock pieces won't work with it. does everything need to be fabricated from the ground up with the new t04e?
thanks in advance for anyones help!
Literally, the turbo is just too damn big to work correctly. It won't even build boost until after 4500 rpm and may not even reach full boost before the rev limiter. You will also experience surge because the 2.3 doesn't flow enough air for the turbo.
