t10 to 92 302 help
Yes it will physically bolt up to the 5.0 engine. The problem is you will need a new flywheel because the 92 has a 50 ounce balance to it it and the 78 has a 28 ounce balance to it. If you use the current flywheel you will destroy the 92.
Make sure you get a 28 ounce flywheel that is the same size and style clutch (either 10 1/2 or 11 inch 3 finger) and you should be fine.
