I posted a question a few days ago regarding a crossmember having a really bad fit to car and think i figured it out. It appears that i was given a tremec crossmember verse a T5 and this may be the reason, anyway i have a T5 coming this friday. My new question is as follows. I understand that some people have to trim a quarter to half an inch from the passenger side shifter hole. I have to do this but am wondering if anyone has had this problem. Did anyone notice if the shifter mounting area (rectangle with 4 threaded holes) is not sitting parallel with the floor cutout? Mine is slightly twisted to the right or clockwise when viewed from in the car. i am using a lakewood scattershield and t5 adapter plate that is installed correctly. I also noticed that the rear trans tailshaft mount is not parallel but "twisted" in the same manner if viewed from the end (As everything is not lined up persay at 12 oclock position but at 12:30 position when viewed from the tailshaft looking forward). the trans bolted up fine and engaged everything as it should but appears as if it not level and I verified this by putting a 6" bubble level on the rear mounting boss and it is off. Weird thing is that everything bolted up no problem? strange. Brian
