T5 Question(s)
spunky4343 said:
Couple of questions
- what is a good donor car to get a T5 ?
- what are the price ranges?
- how difficult is it to change it ?
- are there any pages around explaining it ?
-A 2.3 powered fox body
-All over, I've never bought one but I've seen everyehre from $150 for a very questionible one and up.
-How good are you at working on cars? It's kinda heavy and your on your back most of the time, but it's not to mentaly taxxing.
-About what? Are you swapping from an auto? in that case yes. Are you simply replacing a damaged T-5? If so you shouldn't need any extra info.
spunky4343 said:
i have a 93 lx, it's a 5 speed (sluggish) and i hear a t5 will do the trick.
I'm ok working on cars, but if anything i have a mechanic neigbor so it's cool
Like said before yours is a T-5 anyways.
I wonder if you just need a new clutch or something like that :scratch: I'm no expert since I'm on my first stick in my life :D but I would take it to a transession shop and see what they say unless your friend knows standards.
get a t-5 out of a turbo coupe they are stronger and i believe have lower 1st and 2nd ratios. look to spend like 100 to 300 for a used trans as far as swaping it out if you already got a t5 in it the total swap can be accomplished in under in hour depending on mechanical abillity (no offense) but id say anyone could swap one out in a weekend with ease. get yourself a chiltons book or something it explains how to remove / install a trans
