Drivetrain T5 rattle
Scott7512
153
Branchland WV
T5 trans has a rattle in neutral with the clutch pedal out. When I push the clutch in it stops.
It seems to work fine going through the gears. Since I noticed it, it has been on two 500 mile trips.
I did change the throw out bearing shaft to the steel one and put brass fork bushings in it while changing the clutch but this did not help.
