T5 rebuild questions
  • Thread starter Thread starter bdydrpd88
  • Start date Start date Apr 28, 2010
bdydrpd88
18
  • Apr 28, 2010
Hey guys recently got motor and suspension rebuilt in my old original 2.3 car it now has a built 8.8 rear end new rear and front suspension and a v8 runnin about 300+ hp in it question is about the transmission. I believe this car still has the original T5 tranny that came with the car I know it still had the original 7.5 axle under the rear until i replaced it a few weeks ago been having trouble with the transmission grinding really bad and its very stubborn at changing gears especially under hard accelleration. Can the 4 cyl trannys be rebuilt to withstand the new motor or do i pretty much just need to drop the bread on a rebuilt WC T5? I been getting mixed reviews around town about it some say I can rebuild the old tranny and others have just told me to find one out of a original v8 car. Any ideas??
L
Lawbreaker5.0
543
Texas
Apr 28, 2010
  • Apr 28, 2010
You can buy a v8 gear set and a input shaft and swap it right in I believe. I know a friend of mine had a 4 cyl t5 and he went to a guy that rebuilds t5s, the guy sold him a gear set (already on the main shaft) and installed it with a input shaft. So I don't know if the mainshafts are the same but if they are then it's a straight swap. You'll need a new pilot bearing to fit the v8 input shaft
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Apr 28, 2010
  • Apr 28, 2010
You can buy a z spec gear set and swap it in. My car has a converted 4cyl t 5 in it
L
Lawbreaker5.0
543
Texas
Apr 28, 2010
  • Apr 28, 2010
I plan on converting my stock t5 to a z spec when it needs a rebuild. But man 500 bucks for a gear set. You think a z spec t5 will hold behind a stout 347 with an occasional 100 shot?
F
FoxGT87
5 Year Member
Aug 1, 2009
1,518
St.pete FL
Apr 28, 2010
  • Apr 28, 2010
i went the easy route and bought my transmission from Astro Performance. for me it was the best bang for the buck. rebuild kit, Z spec gears, no hassle... saved a lot of money cause they were in my back yard. i have 4.30 gears and used to have the 4 cyl trans with the 3.95 first gear. i got a 2.90 first gear now. so much better, cruising down the highway is more enjoyable with a .60 OD. i highly recomend the Zspec gear ratio's best thing i have done to the car.
bdydrpd88
18
  • May 2, 2010
so whats some numbers on that gear set how much am i lookin at total to get just the parts cuz i can have it rebuilt for near nothing by a friend at his shop
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
May 2, 2010
  • May 2, 2010
I'd prob look into an Astro or g force gearset in that case. A little more money...but a lot stronger
87GT Drop Top
500
South Florida
May 2, 2010
  • May 2, 2010
ProMotion Powertrain
T5 identification
  • 3054tony
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
AeroCoupe
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 8:51 AM
Rdub6
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
