- Classic Mustang 3-speed Shifter Handle Machined to Fit a Stock T5 Shifter Base .
I purchased this 3-speed shifter, removed the linkage, cut off the base, machined a flat mounting surface, drilled the two mounting holes, and than machined a flat spot to accomodate the bolt heads. * The mounting surface is designed in such a way that much of the pressure from the handle, during shifts, is transmitted directly to the shifter without stressing the mounting bolts.* This handle will bolt up to most stock and many aftermarket shifters.* Reproduction shifter handles like this sell in the after market for over* $100.00 + S&H, and do not have the fit that this handle does.* This handle has the added advantage of being stock original Mustang equipment.*
*** • **** Classic look
*** • **** Correct positioning and angle for easy shifting
*** • **** "Sleeper look" they will never know you are running a T5
*** • **** A classic Mustang shifter boot completely covers the bolted-together area
Link to pictures of item:
http://home.bresnan.net/~karlsenart/handle1
http://home.bresnan.net/~karlsenart/mount1
http://home.bresnan.net/~karlsenart/asembly1
http://home.bresnan.net/~blackmustang/upright1
Ebay link:
http://cgi.ebay.com/ebaymotors/Clas...ryZ34206QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Ebay link:
