T5 swap into 84?
  • Thread starter Thread starter stangguy50
  • Start date Start date May 24, 2005
stangguy50
58
Greenville
May 24, 2005
  • May 24, 2005
I have been flirting with the idea of swapping a t5 into my 84. can i use a t5 out of any fox? and other than tranny, pedals, what else do you have to do? im sure this has been brought up before and sorry if it has. i just know that this place i can get some answer. and also, are there shops that do this? im in MI im just wondering if this is something that shops do.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
May 25, 2005
  • May 25, 2005
If you search for AOD to T5 swap you will find a wealth of info. Most are done on later model cars, but all the hardware should be the same. The only things you will do different are interior trim, wiring (possibly), and have to make sure you have the right flywheel and clutch (earlier cars used smaller ones -- just make sure they are both the same).
J
JohnnyGMachine
123
Easton, Pa
May 25, 2005
  • May 25, 2005
Aod To T5 Swap
I just had an AOD to T5 swap done on my car yesterday at MV Performance. That will probably be one of the best things I'll ever do to my 92 5.0 Notch. My AOD was giving up and the OD went out so it was time. It was real hard on the car to drive around without the OD especially since I have 4.10s. MV Performance did a great job and had it done in just under a day. I bought a T5 swap "kit" from Mustang Parts Specialties which I highly recommend since they give you literally "EVERYTHING"! I got the wiring harness, computer, every fastener nut and bolt necessary. I bought everything minus the transmission and clutch for about $1000. I tried scouring for the parts on my own and it's next to impossible unless you find a complete wreck. The transmission wiring harness is obsolete and very hard to find. I also recommend changing out the computer so that when you push in the clutch the revs drop more gradually unlike using an AOD computer where the revs drop faster. Buy things like the clutch, flywheel, bearing retainer, clutch cable, and an aftermarket shifter new. I upgraded wherever possible. I also went with an aluminum driveshaft which weighs 6 pounds lighter than the stock steel T5 driveshaft. I'd recommend also using 86-93 T5s since they use the same size clutch and flywheels.
John
Dark Knight
2,578
Chandler, Az.
May 25, 2005
  • May 25, 2005
might be a little work, isnt the 84 auto a CFI car? you can use a later flywheel, cheaper to find and it's bigger than the 84's came with.. 10.5 vs 10in, interchangable though..
H
Drivetrain 6R80 to t56 swap
  • Holymoses
  • Apr 25, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
AeroCoupe
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
