T5 Vibration- New to tranny
  • Thread starter Thread starter 92Frankenstein
  • Start date Start date Apr 29, 2005
9
92Frankenstein
223
Minnesota
Apr 29, 2005
  • Apr 29, 2005
I have had mostly autos, and I just got a T5 that I have not tore into yet. The problem is, the person I got it from said that at highway speeds, it had vibration, so assuming that this is only while it is in gear, and goes away in neutral, and is actually something in the tranny, what could it be?
And just for fun, other than driveshaft, what else could cause this, flywheel? Clutch? Etc.
Thanks for the help,
Brian
pisgahhiker
148
Western North Carolina
Apr 29, 2005
  • Apr 29, 2005
Hmm
Maybe flywheel is untrue?
My LX had a vibration in it for awhile I tried 3 diff things.
New clutch setup
New driveshaft
New balancer.
I think the driveshaft and balancer made the most differance.
Was the vibration felt thru the car or in the shifter?
I've heard of sloppy old shifters causing people to run out and buy driveshafts and then have to turn around and get a new shifter.
M
mpswirl
18
  • Apr 29, 2005
I had that exact problem and believe or not it turned out to be my clutch fan. It was going bad and when the engine was revved up at high speeds it shook real bad. Otherwise it might be bad u- joints in the drive shaft. They may not feel loose but they might be too tight take them off and move them to see if there tight.
9
92Frankenstein
223
Minnesota
Apr 29, 2005
  • Apr 29, 2005
Well, this is good, as most personal experiences seem to be not related to the tranny itself, and everything else is getting replaced.
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
R
Drivetrain Clutch
  • Robman8028
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jul 2, 2025
AeroCoupe
