Hey everyone. New to the forum but not new to the Fox Body world. Not an expert either by any means. I've had my '89 notch since 2005. I figured I'd share my experience with my recent T56 Magnum install. Bought the close ratio version as a kit in the spring that came with everything I needed except for a driveshaft. My engine is an R block 347 with AFR 185 heads NA. Dyno'd @370/362whp/tq. So nothing crazy but definitely too much for the infamous T5 the way I like to shift. (That's what it made with the stock A9L computer and SCT chip. I now have a MSPNP2 and am still currently tuning it)
Parts:
-Tremec T56 Magnum Close Ratio
-McLeod RST Dual Disc Clutch
-QuickTime SFI Bell Housing
-Ford Racing 31 Spline Driveshaft Yoke
-SN95 Clutch Fork (had to modify for my application)
-Couple of pigtails for the reverse light switch and reverse lockout solenoid
-Stifflers Transmission Crossmember
I run BBK long tube headers which made the install a bit of a pain in butt. In order to even get the Bell Housing installed I had to unbolt both headers. Then came the test fitting. This involved bolting the transmission in a few times to see what needed to be modified. I had to trim one of the tabs on the passenger side of the trans housing. I had to massage the trans tunnel where the shifter base sits. I had to trim about an inch off the clutch fork and modify the hole for the cable. I had to massage the driver side header for clutch fork and cable clearance. I had to adjust my adjustable clutch fork pivot ball which is recommended to use with dual disc clutches as they are thicker. Then I had to measure my driveshaft and see how much needed to come off. I took it to a driveline shop where I had them shorten my driveshaft by exactly 3 inches and install the 31 spline yoke. Once it was finally all installed I had to do a small amount of wiring. I had to wire in the reverse light switch as well as the reverse lockout solenoid. The reverse lockout solenoid I wired into my LineLock/2 step button on my shifter. Some wire it into the brake pedal switch but to me I already had a switch readily available and easy to tie into close by.
It was a successful summer with the new transmission and clutch. Clutch feels great, light and very smooth. The transmission feels great too and it feels cool driving a 6 speed Fox. I ran Redline synthetic ATF at first and then I ordered Tremec Transmission oil right from Tremec to replace the Redline after breaking it in.
The factory speedo cable also reaches and works for the T56 Magnum install. All I had to do was adjust where it was clamped on the firewall to get extra length.
Parts:
