I am in the middle of swapping my 3550 over to a viper spec t56. The connectors are now on the opposite side of the trans so I extended the wires and hooked up the vss and the back up lights. But on the rear of the 3550 right behing the shifter is the neutral saftey switch? Or at least thats what I think it is. Correct me if I am wrong. There isn't a place on the t56 for it that I see. So my question is do I bypass it? Any problem with bypassing it beside running the risk of starting it in gear or while its already running?
Also on there it a reverse lock out that has to be wired, ddperfomance sugggested may be to the brake switch . Its just to keep you from shoving it in reverse while running through the gears. Any of you guys wire it off the brake switch or did you do something different?
