T5z diagram
  • Thread starter Thread starter Leonforte
  • Start date Start date Jan 21, 2006
L
Leonforte
  • Jan 21, 2006
Does anyone have a good diagram of the T5z tranni which labels all the parts.I'm trying to find the neutral safety switch,backuplight switch, the plug that fills it up and the drain plug and what's the black ball on top of the tranni for? Also what's the best way to add the fluid wnen the tranni is in place?
Thanx-Tom
jcode68
892
Massachussetts
Jan 22, 2006
  • Jan 22, 2006
Good thread, am interested in these answers as well. Hopefully the bump will help.
66Runt
680
Jan 22, 2006
  • Jan 22, 2006
Don't have a picture, but...
The Neutral Safety switch is at the top front. The reverse light switch is towards the rear of the main case on the driver's side (as mounted in the vehicle).
Don't know about a "black ball" on top, unless it is the vent.
The fill plug is also on the drivers side. It has a 3/8" square hole for your ratchet to fit in. The drain plug looks the same but is on the bottom.
To fill it up, (car level) remove the fill plug, get a hand pump for your quart bottle and pump in fluid until it just starts to come out. IIRC, just shy of 3 quarts. Put the fill plug back in.
Another way is to fill it on the bench before install. You will need a tail shaft plug, and you will spill a little when swapping in the drive shaft.
Good luck,
Scott
SoCalCruising
2,437
SoCal
Jan 23, 2006
  • Jan 23, 2006
For me (T-5z), fill and drain plugs were on Passenger side. Reverse light switch is two threaded "screws" sticking out on driver's side, mid-tranny. Neutral safety switch should be a short harness at top, driver's side, above reverse switch. Black plug on top is mystery to me, too. I thought it might be a fill port, but didn't matter since Iwas not filling until installed. I used a hand pump from Pep Boys.
66Runt
680
Jan 23, 2006
  • Jan 23, 2006
Fill is on passenger side
My mistake,
I've got the T5z as well. Forgot which way I had the car facing in the garage when I filled it.
The reverse light switch posts aren't threaded on mine. They looked like threads until I tryed a nut. On mine they are circular ribs to hold on the friction fit plug.
SoCalCruising
2,437
SoCal
Jan 24, 2006
  • Jan 24, 2006
That's why "screws" was in quotation marks.
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
A9L on 94 engine, no priming injector pulse?
  • Wallyman
  • Jun 17, 2024
  • Other Auto Tech
2K
Other Auto Tech Jun 24, 2024
Wallyman
M
  • mnky99
  • Sep 5, 2025
mnky99
M
