Tach install help, ASAP
  • Thread starter Thread starter 88GT4u2nv
  • Start date Start date Jun 6, 2005
88GT4u2nv
60
Wa
Jun 6, 2005
  • Jun 6, 2005
I just finished installing an Autometer SportComp Tach. Sarted the car, and it ran between 1500 and 2000 off through the whole RPM range. I connected the coil wire to the smaller of the 2 wires coming out of the coil (green), was this the correct wire? Is my tach broken?
Danny-Boi
97
  • Jun 7, 2005
The Green wire (coming out of the tach) connects to the green wire that attaches to the plug which attaches to the coil.
Danny
HISSIN50
34
129
Jun 7, 2005
  • Jun 7, 2005
Right, the tach signal wire goes to the negative coil wire.
Are you sure none of the cylinder wires are cut on your tach? wires get cut for lesser number of cylinders (6 and 4 bangers).
what if you rotate the gauge in its housing a little? I had one that would read funky if not rotated just right.
Good luck.
88GT4u2nv
60
Wa
Jun 7, 2005
  • Jun 7, 2005
hmm, there is a little wire out the back which is cut. ill put them togeather and see what happens. thanks
281pony
2,681
Oly, WA
Jun 7, 2005
  • Jun 7, 2005
i agree with hissin, if its reading but inaccurately. definately sounds like calibration with that wire being cut.
NosPony
278
Canton, Il
Jun 7, 2005
  • Jun 7, 2005
Yea all three wires need to be connected. Otherwise, you are reading rpms at a 6 or 4 banger rpm.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jun 7, 2005
  • Jun 7, 2005
+1 more for agreeing. Reconnect the wire and you'll be all set.
88GT4u2nv
60
Wa
Jun 8, 2005
  • Jun 8, 2005
this damn thing is pissin me off. so i pull the cut wires out of the back of this thing just so i can figure how to reconnect them, and when i turn the car on the tack no longer reads, checked the connection with coil wire and its fine along with the others. it does twich and spike when i start the car. also the shift light still works and i can still adjust it, just now when i adjust it the needle moves up and down with the adjustment. damnit, am i just stupid or sumthing?
281pony
2,681
Oly, WA
Jun 8, 2005
  • Jun 8, 2005
sounds like you bought an f'd up tach. definately risky buying items like that online.
the shiftlight works though? sounds to me like the needle might be damaged/broken if its not reading. good luck with it
88GT4u2nv
60
Wa
Jun 8, 2005
#10
  • Jun 8, 2005
  • #10
well the tach was free, perk of working at a car dealership, also, it had just been working not minutes before, it seemed only too scew up when i messed with the cut wires. oh well, ill hook the wires up and see what happenes i guess.
88GT4u2nv
60
Wa
Jun 13, 2005
#11
  • Jun 13, 2005
  • #11
another step closer to throwing it away, so i havnt had a chance to connect the wires, but when i officialy installed the tach, (screws instead on glue) now all the sudden the shift light clicked on and wont shut off, its a little bit dimmer than when it signals, but its still bright and saying on, when i get to the shift point it gets brighter then when i drop below those rpms its resumes its dimmer but still on action.
and another thing, this may be jst because how i hooked the power, and dimmer wires up but when i turn on my blinkers im getting a wierd clink noise from inside the fuse box. WTF MATE!! why does it seem i always have the big probs with the small installs? oh well
88GT4u2nv
60
Wa
Jun 14, 2005
#12
  • Jun 14, 2005
  • #12
ttt
88GT4u2nv
60
Wa
Jan 27, 2006
#13
  • Jan 27, 2006
  • #13
ttt
Bad92GT
The 5 Minute Plan Man
Jun 10, 2004
492
SC
Jan 27, 2006
#14
  • Jan 27, 2006
  • #14
do you run any msd products?
M
mkk50
109
29
39
Jan 27, 2006
#15
  • Jan 27, 2006
  • #15
id check where u grounded the tach too, i had a bad ground wire on mine, and when i turned the headlights on, the shift light would light up, and the tach would go up to 5k and sit.
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
  • dan50
  • Jul 18, 2026
dan50
65 Mustang: Tried to install a tachometer from Oreilly's with no success.
  • spearce
  • Mar 26, 2025
1965 - 1973 Classic Mustangs -General/Talk- May 19, 2026
spearce
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
T
Engine 1992 5.0 Died while running, crank no start, Tach Jumping
  • ty50650
  • May 1, 2024
2K
Fox 5.0 Mustang Tech May 4, 2024
Mindseye007
