  • 1994 - 1995 Specific Tech
Tackling A Swap
  • Thread starter Thread starter BurningRubber
  • Start date Start date Dec 25, 2004
BurningRubber
1,865
24
58
Dec 25, 2004
  • Dec 25, 2004
Merry Christmas guys.. My freind and I might be doing an engine swap in his 98 V-6 Stang. Heres the scoop. We have easy acess to a 302, and parts are cheaper with a 302. I know that these cars had the 4.6's in them for that year GT. So my question is would it be any more difficult then just the normal swapping the wire-harness over and getting all the right manifolds? Also the car is not a 5 speed.. its the auto, would that bolt right up or would it be an issue? Thanks
Also.. I know that we would probaly break the rear axle in a matter of time but the concern right now is wich motor would be more of a direct swap.. We were thinking a carbed 351.. same block and dimensions as a 5.0 right?
TrueBlue95GT
966
Connecticut
Dec 26, 2004
  • Dec 26, 2004
If I'm not mistaken, the only thing you have to change over besides what you already said is the motor mounts. The K-member is the same. The 351 is a taller motor though. You're going to need drop mounts and a taller hood.
M
mustangman33
262
Chicago, IL
Dec 26, 2004
  • Dec 26, 2004
If he goes carbed, his stock hood will work, he'll just have to get a torker II intake for a 351w, motor mounts will work also, not very sure but I thought the K member was different also, because with a 4.6 the motor sits differently than the 5.0. I should be doing another 351w swap on my 97 vert in the spring, so I would like to know more also.
nunly94gt
1,595
Mobile, Al
Dec 26, 2004
  • Dec 26, 2004
Right up my alley almost. Ok the 351........ well from experience I will say dont do the carb! I ran into lots of problems and I bit of more than I can chew. I have seen a windsor with EFI and it hauled.
On the tranny swap. I swaped from AODE to the 3550. Simple it was done it a couple hours. Need a different computer and cantrary to poular belief you dont need to change the wiring harness. Just stick a paper clip or something in the neutral safety switch to bridge it open. Also make sure the little shift lock is pressed in and taped down good. It could cause a major if you forget.
Most of all GOOD LUCK!!!!!!!!
94YellowStang
114
Hayden, AL
Dec 26, 2004
  • Dec 26, 2004
someone on this forum swapped a 95 5.0 motor into a 96 v6 body.He said the k-member are the same as the 94-95 v6s they only changed them for the 96+GTs,just need 5.0 motor mounts.
M
mustangman33
262
Chicago, IL
Dec 26, 2004
  • Dec 26, 2004
he should be able to use his v6 motor mounts if everything else will fit, other than that, bell housing, computer for trans, headers, oil pan, and brackets for the swap, and the dimensions are not the same for a 302 and 351W, the 351W is wider than the 302, so if he does the swap carbed, make sure he gets the torker II.
D
dirtyo2000
31
  • Dec 26, 2004
hey since you seen one done what type of strut tower brace did he have because im having problems finding one for my car
M
mustangman33
262
Chicago, IL
Dec 26, 2004
  • Dec 26, 2004
spent so much money on my 351w so the rest of the car is still stock, after rear end is swapped and nos, suspension is next on the list, but the bodies are still the same, you should just use one from a 5.0
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
