I've got parking lights, no turn signals and no brake lights.
Ive been staring at Ford's wiring diagrams, and I hadn't had a chance to really tear the car down to look for the harness as it travels other than the trunk and under the dash.
It started when I had the car painted, just the one taillight would light up with the parking light, but wouln't change state when the brake was pressed or when turn signals were on, so missed ground or crimped wire, right? Now its gotten to the point where its blowing fuses and the vehicle has no operating brake or turn lights.
Even the center is out, which is a different harness/segment of that circuit altogether.
Worked on it today, found the orange/light blue burned in half on the chassis side of the taillight harness in the trunk about 3" from the fuel cutoff switch. Soldered it and thought I was done, now 4 fuses later I'm frusterated as all hell.
The fuse won't initially blow, I've shaken as much of the harness as I can find, the only thing I can potentially think of is that it happens after a period of time of more than 2-3 minutes, and possibly when starting the vehicle.
However, once I gave up, it hadn't blown after 30 minutes of molesting the pedal and multifunction switch in testing.
I'm as lost as ever, and I don't even know where to start. I thought about buying a new multifunction switch, and pulling the car's interior, removing all aftermarket wiring in the vehicle and taking it to a dealer. Yikes.
EDIT: The lights also seem dim, until you move the multifunction switch half left or right.
I don't see anything at the point the taillight mounts, the harnesses there or where the harness starts in the trunk, but has anyone run into anything like this and have an idea on where to look? I guess its a bad hot lead for the bright side of the bulb, but I don't know if there's a better way to check than just to find out which wire it is and work my way back to the front of the car.
