taking apart headlights
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
i think it was sanman that did it for his projector install, but anyways i wanted to take apart the headlights on my friends car to remove the amber reflector. does anyone have any tips to make the removal easier?
Heat up your oven to 250*, then turn it off.
Put your headlight assembly inside the oven on a cookie sheet, lense side up.
Leave in for 10 minutes, then remove and pry apart. You have to re-heat it in order to reactivate the "glue" that seals it up, but it's also a good idea to use some silicone sealant when you get it back together again.
