Taking out rearend!! Help!!!
I need anyone that can help me. I am getting ready to take out the rearend of my mustang to get it ready and prepped so when i sell my 347 stroker kit i can buy the parts that i need to redo my rearend, and get it degreased and prepped to go to the shop once i get all the parts i need. Had anyone taken out the rear before? Can anyone offer tips on how to go about this? I have stock drum brakes, upper and lower control arms, springs shocks, i know i need to disconnect all those and the brake lines.
Thank You for your help
nope never been doen... :D to do it: disassemble the brakes and disconnect the e brake, then unbolt the shocks from the rear, followed by the driveshaft. remvoen the 4 bolts that hold the stock control arms to the body and pul the rear out the back.
Definatly do the drive shaft first. Leave the car in gear and have a buddy push the brake down so you can get enogh force to brake the bolts lose.
Disconect brakes.
Now get a jack "preferably a harly davidson jack" And take the pressure off of the connecting points by lifting up the housing a little, with the car supported by jack stands.
Now remove the sway bar and disconect the lower controls then shocks then uppers and finaly lower the housing down most of the way and then disconnect the quad shocks.
I say disconnect the quads last cuz they will move with the axle but if the rear falls off the jack they will not only slow the fall but not let it go all the way to the ground.
doing this saved me from getting crushed when i did my'n.
Good luck!! And the best of Patience to you!!
Your two best friends while doing this WILL be a propane torch and a impact wrench.
Also when you put the springs back in make SURE you seat them right. other wise your car will not sit at the right hight.
The very ends of the coils on the bottm of the springs need to face the drivers side of the car.
I did not do this right the first time and my rear sat a inch higher then stock.
yes that is for both sides of the car.
For installation reverse the take off order.
Do Quads, Uppers, shocks, then lowers.
do the lowers last so the rear end can hang from the car and you can use your jack to compress the spring and piviot the lowers into place to bolt up to the rear.
