Tb for a 95 cobra intake
Edelbrock, BBK, Accufab are all good. Most people say don't go higher than 65mm on an N/A car, but i think its wise to go with the size of the intake opening, which on a cobra intake, is 70mm.
well, im planning on purchasing the intake manifold, if i can ever find a 94/95 cobra one, and some 3.73 (i think) gears, but i've heard that while putting on the intake manifold it's good to go for a bigger TB, and that i'll feel more power. Thanks for the help.
You can pick up 94/95 cobras for $250-$300 in the parts section or on ebay. The opening in the intake is usually 68-70mm. An Explorer intake is also a deal, but you will need an intake elbow. 65mm is ideal for mild engines. Unless you get big port heads and a big cam, 65mm is all you will need. Bigger will lose bottom end power.
no he's talking the EGR in the center of the intake. Used on the FOX body platform. The SN95's lower still had the Hole for the EGR but the Stock upper doesn't. I don't believe the cobra Does either but i've never paid attention.
95GTV8 said:
so, if i get the cobra intake manifold, and keep my stock 95 gt tb, i won't be losing much power? so it'd be better to get other mods 1st, before getting the 70 mm TB?
i think so, u seen the sticky at the top with the CFM flow for intakes? makes no sense to have a nice flowing tb and right behind it a more restrictive intake
