TB/Intake options for SD car
  • Thread starter Thread starter DW5.0L
  • Start date Start date Aug 5, 2005
DW5.0L
172
Florida
Aug 5, 2005
  • Aug 5, 2005
I am in the process of assembling my engine after a rebuild. The EGR studs are toast and so is the stock EGR spacer. So, I can either find a junkyard spacer and get the Trick Flow stud kit or go another route.
What are other SD cars running as far as an intake and TB? I am thinking about an FMS 65mm TB or Edelbrock 65mm and putting it on Performer 5.0 intake. Will that upset the driveability on my SD car?
Does the TMOSS lower ported intake flow as good as the Performer?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Aug 5, 2005
  • Aug 5, 2005
I am running an Explorer 65mm TB and Cobra Intake on my SD car.
Car runs no different than before the install.
slo65
448
Southern California
Aug 5, 2005
  • Aug 5, 2005
did u notice a sotp difference
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Aug 5, 2005
  • Aug 5, 2005
Yes i did actually.
Above 2500RPM the car pulled much harder and felt like it had more grunt.
I have a full exhaust too (headers, off-road pipe and cat-back) so the engine must have loved the additional air.
Now i just gotta ditch the E7's.
DW5.0L
172
Florida
Aug 5, 2005
  • Aug 5, 2005
Ok so a larger throttlebody and the right intake kit for no power loss will work. I want an intake that doesn't fall off like stock set up, and no lower lower RPM power loss.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 5, 2005
  • Aug 5, 2005
I got a 96 Explorer intake manifold with the 19# injectors and 65 MM throttle body for $250. The Explorer flows about the same as the GT40 manifold. It works great, a local junkyard sourced it for me.
The stock Explorer linkage didn't come anywhere near fitting, so I made an adapter plate for the throttle linkage so I could use the 65 MM throttle body.
Also see Tmoss's adaptation technique at http://www.veryuseful.com/mustang/tech/engine/ConvertingExplorer65mmTB.pdf for modifications to adapt the 65 MM Explorer TB to a Mustang
Another method is to remove the old bracket from your old TB by grinding off the end that is mushroomed over. Do the same thing to the Explorer TB and then drill and tap the shaft for a 10-32 machine screw. Put the bracket from your original TB on the Explorer, and install the screw with a big washer. You might want to put some Loctite on the screw threads before tightening the screw down.
DW5.0L
172
Florida
Aug 5, 2005
  • Aug 5, 2005
Thanks for providing another options and install information.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Aug 5, 2005
  • Aug 5, 2005
No
and No - the ported stock set up flows ~190cfm tops and the Performer flows ~220cfm.
DW5.0L
172
Florida
Aug 5, 2005
  • Aug 5, 2005
Thanks. Looks like I will go with the Performer 5.0 intake. Just have to decide on the right TB size for my setup. I found a good deal on the intake and they suggest going with an Accufab versus an Edelbrock TB.
BaXTeR3221
917
Orange County, NY
Aug 5, 2005
#10
  • Aug 5, 2005
  • #10
The big thing that affects SD is the cam. Intake and tb shouldn't make a difference.
DW5.0L
172
Florida
Aug 5, 2005
#11
  • Aug 5, 2005
  • #11
Ok, I didn't change the stock cam profile. Appreciate all the input guys.
slo65
448
Southern California
Aug 5, 2005
#12
  • Aug 5, 2005
  • #12
txstang84
1,639
42
69
Tuscola, tx
Aug 5, 2005
#13
  • Aug 5, 2005
  • #13
there are a couple of aftermarket cams you can run with SD aren't there? i seem to recall seeing a couple of the fellas here with some type of crower cam...slightly warmer profiles, but not so bad that it confuses the computer...
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Aug 5, 2005
#14
  • Aug 5, 2005
  • #14
SD Computer friendly cams
Crower 15510, 15511
Crane 2030, 2031
Comp cams XE264-XE270
Keep duration @ .050" at less than 220° and lca at 112-114° and things should go well.
Black 93 Fox
1,995
Vancouver,Washington
Aug 6, 2005
#15
  • Aug 6, 2005
  • #15
You dont have to buy a stud kit. I just went down to the local hardware store and got some long bolts worked great.
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine Sick of stock TB and EGR spacer...
  • 91GTstroked
  • Dec 15, 2024
Fox 5.0 Mustang Tech Dec 19, 2024
General karthief
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Engine Popping noise in the intake. Frustrated still.
  • esteban31065
  • Apr 6, 2025
Fox 5.0 Mustang Tech May 23, 2025
gkomo
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
