  • SN95 4.6L Mustang Tech
TB/Plenum Install HELP!!!
  • Thread starter Thread starter stng
  • Start date Start date Nov 22, 2005
stng
182
  • Nov 22, 2005
Ok so I just now got done finally installing my Dragon Plenum, A 70 mm Accufab TB and a K&N FIPK 2... I start the car and it idles just fine, throttle response is way better than stock, as of SOTP power meter to early to tell. Here is my problem: every time I touch the throttle/accelerate of idle I hear a squeaking sound, best way to describe it is that it sounds like a belt slipping... It only does it for a second, but it does it every time I hit the throttle... Any help would be very much appreciated...
Thank You
stng
182
  • Nov 22, 2005
Ok the car is still making that squeaking sound under acceleration, no CEL, and no idle problems/drivability problems. It sounds like it is coming from the TB/Plenum. I have rechecked all the vacuum lines and they are all connected. I am sure I tightened down every thing correctly.
stng
182
  • Nov 22, 2005
Bump Someone has to have some input?
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Nov 22, 2005
  • Nov 22, 2005
Is it a whistle or a squeak? You may have air sucking in from the point the TB mounts to the manifold...unlikey if you used a gasket...or if you didn't get a good seal between the TB and plenum. I used a light bead of RTV when I attached my TB to the plenum.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Nov 22, 2005
  • Nov 22, 2005
it might be the air coming in since you eliminated all the most restrictions so the air just comes in smoother and you can hear it getting sucked in when the TB blade is opened
stng
182
  • Nov 22, 2005
I guess it is more like a whistle than a squeak, only does it when you tap the throttle...
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Nov 22, 2005
  • Nov 22, 2005
then it is the rushing air coming in i get that when i accelerate the car a little too it's nothing to worry about
stng
182
  • Nov 23, 2005
Ok so I know people are saying this is normal, however it is just way too loud to be... The noise also goes away after the car get hot, and is the loudest on cold start up. I am going to tear every thing off again today and see what I can figure out...
D
Dragstr05
643
Stafford VA
Nov 23, 2005
  • Nov 23, 2005
My buddy has a 2.2L sonoma that he has a number of bolt ons for, and after he put his new TB on it got a nice wistle from the air rushing in when the throttle is depressed. Its almost loud enough to sound somewhat like a very small turbo spooling up.
stng
182
#10
  • Nov 23, 2005
  • #10
Yeah its pretty loud, it sounds like a belt slipping, and almost part of me wants to think that is what it is, especially when it is the loudest when it is cold. I will let everyone know when I fix it.
BooWFO
991
Louisville, KY
Nov 23, 2005
#11
  • Nov 23, 2005
  • #11
step 1. turn stereo up
step 2. no more noise you shall hear.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Nov 23, 2005
#12
  • Nov 23, 2005
  • #12
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
Nov 23, 2005
#13
  • Nov 23, 2005
  • #13
i have the same thing on mine, i put on a Demolet CAI, MAC75mm tb and Plenum and got a pretty audible whistle between 1000-1500rpm. i thought it could be a leak between the plenum and manifold, since i had a spacer, so i now had 2 places there could leak, but i took it all off, put new gaskets in there and more rtv sealent, and still have the whistle. its just the intake now sucking in lots of air than it did before.
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
squeak93
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
O
Need a hand: Hanging idle with all new parts
  • Overused03
  • May 15, 2024
SN95 4.6L Mustang Tech May 21, 2024
Overused03
O
