TB question
  • Thread starter Thread starter scupking
  • Start date Start date Apr 13, 2007
1 of 2 Next Last
scupking
1,186
Enfield, CT
Apr 13, 2007
  • Apr 13, 2007
I have RPM planets 75mm TB and plenum kit. The only issue I'm having is when you lightly press the accelerator down from a dead stop it takes a little extra force. It gets really annoying when in traffic. Once you press it down just a little it becomes unstuck and feels normal until you let your foot off the gas. It’s kind of hard to explain.
Skud
493
Saskatchewan
Apr 13, 2007
  • Apr 13, 2007
Not a mustang, but I have the exact same problem with my focus. It has the stock TB. It seems to only do it after the car has warmed up.. It makes it really hard to drive in slow traffic without jerking the car back and forth..
Riley
CobraRed_96_GT
1,421
UCSD/La Jolla
Apr 13, 2007
  • Apr 13, 2007
buy a different throttle return spring
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Apr 13, 2007
  • Apr 13, 2007
what brand is your TB?
scupking
1,186
Enfield, CT
Apr 13, 2007
  • Apr 13, 2007
I have a C&L Upper Inlet Plenum and a PRO Products 75mm T-body.
BennyBlown2v
1,233
Carmel, INdiana
Apr 14, 2007
  • Apr 14, 2007
my honda does this - my mustang with professional products 75mm tb doesn't
BurningRubber
1,865
24
58
Apr 14, 2007
  • Apr 14, 2007
I have a Professional Products 75mm throttle body also, its smoother than butter... aka... better than stock.
Are you 100% positive the cable is attached correctly? PP has a tricky setup.
scupking
1,186
Enfield, CT
Apr 14, 2007
  • Apr 14, 2007
Thats probably my problem but I don't see any other way to hook my throttle cable up to this TB seeing as its some what different then the stock one. Do you have a pic of yours? When I get home I will post a pick of how I have it.
scupking
1,186
Enfield, CT
Apr 15, 2007
  • Apr 15, 2007
bump
Stangsgrl
132
Mesa, AZ
Apr 15, 2007
#10
  • Apr 15, 2007
  • #10
my bf's accufab 75mm tb does that,
but my accufab 70mm doesn't...
BurningRubber
1,865
24
58
Apr 15, 2007
#11
  • Apr 15, 2007
  • #11
Let me check and if I find one I will post it up.
Heres the best I got, not too detailed with the throttle cable, but its up in that slip below and just to the right of the return spring, you can kind-of see it.
scupking
1,186
Enfield, CT
Apr 15, 2007
#12
  • Apr 15, 2007
  • #12
This is how I have mine.
hotmustang331
2,967
Bastrop,TX
Apr 16, 2007
#13
  • Apr 16, 2007
  • #13
My car has the same problem. And im thinking that its also causing my VERY light throttle low RPM miss. In the same RPM band if I give it a little more gas, car runs SMOOTH all the way through...but if im very light on it or let off while moving in gear, it misses.
SO I think whats happening is that the TB blad is closed too much and thats causing the sticking (vacuum). the IAC is having to flow alot of air to keep the idle right. And then on top of that for ME, I dont think the EEC KNOWS when my throttle is open that slight amount and isnt supplying the fuel needed.
Thats my guess...ill check into it tomorrow
scupking
1,186
Enfield, CT
Apr 16, 2007
#14
  • Apr 16, 2007
  • #14
My problem is more like a physical problem with the accelerator/TB. It actually takes force to un stick it from a stop or when ever I let my foot off of the peddle. So what happens is I go to push down on the accelerator but it requires more force then usual to start off. So when it dose un stick my car jumps forward.
Skud
493
Saskatchewan
Apr 16, 2007
#15
  • Apr 16, 2007
  • #15
I can think of two causes:
1) I think this could be solved by adjusting the stop screw inward on the throttle body a *VERY* slight amount. Just enough to solve the issue, but not enough to cause the car to idle higher. This would prevent the throttle body plate from "fully" closing, seating in place and getting "stuck".
2) Heat: I think this may be a combination of #1 and this. As the engine heats up, the plate may have a greater expansion than the housing. When the plate heats up enough, it is fully closing and getting stuck. The solution would be the same as #1. *VERY* slightly adjust the setscrew..
On my focus (sorry, not a mustang but the same idea) my car is fine in the winter at all times and in the summer, until the car warms up. Then I experience the same problem you're having. The gas pedal takes that little bit of extra force and then works fine.
Does your car do it all the time? Check it when the car is cold and see if it starts doing if after it's warmed up.
Thanks!!
Riley
BurningRubber
1,865
24
58
Apr 16, 2007
#16
  • Apr 16, 2007
  • #16
That doesnt look set up right. I beleive the head on the end of the throttle cable is supposed to pop in both sides and sit evenly across. It looks a little twisted and at an angle there.
speedfreak98r
Banned
Jan 31, 2006
Houston Area
Apr 16, 2007
#17
  • Apr 16, 2007
  • #17
Cut some coils off that bad boy. Looks like they're all bunched up.
Skud
493
Saskatchewan
Apr 16, 2007
#18
  • Apr 16, 2007
  • #18
Indeed..
hotmustang331
2,967
Bastrop,TX
Apr 16, 2007
#19
  • Apr 16, 2007
  • #19
Yes, my car does that too but really only while im moving and in gear and there is more vacuum on the motor....thus sticking the TB blade even more. At idle, it will do it sometimes...and yes it causes a slight buck sometimes.
I was just expanding on what I think my specific problem is, with the missing haha. Im haveing the same problems as you + some extra things that I mentioned.
scupking
1,186
Enfield, CT
Apr 17, 2007
#20
  • Apr 17, 2007
  • #20
Well today I got in the car and pressed the accelerator down before I started her up and I could push it down with out a problem. So it does sound like it could be a vacuum issue as mentioned a few post up.
1 of 2 Next Last
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
Screamin Demons Worth It N/A?
  • Blackout67
  • Oct 20, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 20, 2025
Engine Stock TB - smoke test - leaking bad
  • R82148V
  • May 18, 2025
2K
Fox 5.0 Mustang Tech Jun 5, 2025
R82148V
What is this noise?!
  • squirrel0420
  • Jul 3, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 4, 2025
horse sence
is my car dead
  • kenzo0315
  • Jun 30, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 8, 2025
kenzo0315
