Ok, i've been diagnosing this problem for awhile, and i might have actually put something up a while ago, but this is where i'm at:
My car dies when it's warm, but when cold, idles beautifully.
255lb pump, bbk fpr, 39 lb injectors, 42lb forced maf, turbo.
It hasn't left the garage yet.
timing is dead nuts at 10' and the fpr will only let me go down to 40psi for some reason. I set it with vacuum off of it, and that's all the lower it would go. Doesn't matter, because with the mismatched injectors and maf, it likes to be at 42. I'm thinking that it's getting to the point where it gets warm and doesn't reduce the amount of fuel it's giving, and leaves the timing down, not allowing it to advance.
Is the only temperature gauge the one right behind the thermostat? Does this control the gauge and the engine temp or what? Is there a way to check the sensor itself, or should i just go and get a new one and see if that fixes it?
Any suggestions are welcome as the car is sitting in my parents garage and they want it out!!! I gotta get it back on the street!!!
Thanks!
Lee
Thanks!
Lee
