TFS Head install
  • Thread starter Thread starter QDRHRSE
  • Start date Start date May 29, 2004
QDRHRSE
1,590
Palmdale, CA
May 29, 2004
  • May 29, 2004
I'm putting in a set of ported twisted wedge heads. I have questions. Do I need a special length pushrod and how much piston to valve clearance do I have? My cam has .533/.544 lift. I know I'm cutting it close. I have a basically stock bottom end. Anybody? I know as recently as yesterday somebody said .540 is the max but I've seen .550 advertised. Please help. TFS heads are a PITA...you need special tapered head bolts too.
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
May 29, 2004
  • May 29, 2004
im pretty sure you need new pushrods....thats about all i can help
QDRHRSE
1,590
Palmdale, CA
May 29, 2004
  • May 29, 2004
Thanks. Summit said 6.70 . Stock is 6.2 I think. I appreciate your help!
houstonstangguy
979
Houston, Texas
May 29, 2004
  • May 29, 2004
i think my pushrods were 6.75"
also you might wanna ask about the stock springs on those heads. i know you dont have as much lift as i do but i had to get the upgraded springs and I cant remember where the stockers end lifting. make sure you check because im thinking it was like .530/.540 area, of course it was 7 months ago so i cant remember, i just know i needed them.
good luck
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 29, 2004
  • May 29, 2004
See http://www.trickflow.com/product/twisted_wedge/info_pages/twiswedge_inst_frame.htm for help
blown1989saleen
1,397
oxford,pa
May 30, 2004
  • May 30, 2004
you should actually check PTV clearance on ALL cam installs, in this case i think youll be real close and and prolly wont be within specs. youll need 6.70"-6.75" hardened push rods.
Scott
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
Engine Head gasket port matching plus head/intake port alignment
  • PonyGTrider
  • Dec 10, 2024
Fox 5.0 Mustang Tech Dec 12, 2024
PonyGTrider
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
9
Does anyone else have a combo close to this
  • 90Stanger302
  • Dec 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 25, 2025
Qtrhrse23
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
