The best Mustang picture thread ever! Car+Motor pics with combo details.
DAJ352
74
Gainesville, FL
Readers Rides from my Facebook page.
Niles Frazier Mustang
417 SBF high port 255 a2w single 98mm Holley Dominator EFI 160 injector on C16.
Rick Ramirez 93 Mustang.
331, C-4 with a reverse manual valve body, 2800 stall, 8.8 31 spline, 4:56 with spool, full interior. Car is driven both at track and on the street with best time of 11:51.
Shaun Evans 1990 GT AKA "Karma"
306ci - Ported heads and port matched intake, E303 cam, 1.6 rr, 42lb injectors, Pro-M maf, Vortech V3 supercharger on 12lbs of boost.
Tremec T5 with Auburn locker, 5 lug swapped with disc brakes all around and 03 Cobra brakes with drilled and slotted rotors on the front and 3.73 gears.
Pete Towne Mustang daily driven in the summer.
306ci - GT40P Heads, F303 cam, Vortech Supercharger, Vortech Aftercooler, Complete -8,-6 fuel system 340 pump Tremec TKO600
445rwhp before aftercooler
Vernon Pitts 1989 Saleen Mustang
8.2" deck 358 cid, Custom air/water I/C with 2.8L Kenne Bell S/C running on E-85. Best ET to date 5.33 in the 1/8 mile at 133+ mph on a 26x8.5 Hoosier at 3,150 lbs.
Tony Schenk 86 Mustang GT
347ci - Stock Block, Trick Flow High Port Heads, Comp Cams Custom Solid Roller, 13.6:1 On E85
C4 With 4300 Stall Converter
3.73 Rear With 28/11.50/15
2760lbs
Alisha N Clint Dungan 1990 mustang GT
Completely rebuilt everything replaced or repaired. 900+hp on 16psi and pump 93 fuel F1R Procharger equipped 351W Dart Iron Eagle Block 401ci Callie’s crank and rods JE forged dish pistons solid roller comp cam custom grind cam. Jessel shaft mounted rockers TFSHP cnc ported heads Super victor efi converted intake. Accel Gen 7 DFI system Circle D stage two converter Dynamic Racing C4 transmission with Gear vendors overdrive. Built 8.8 rear end with ford 9 housing ends 31 spline strange axles alburn pro differential. Best ET so far was 10.15@139 mph 3700lb street car still trying to get the 60 ft figured out. Then I’ll turn it up and put some C16 and 20psi and see if I can get into the low 9s maybe high 8s fingers crossed
