the big project
68steed
i am looking to put a 347 into my 68 stang this coming spring. before i do the motor work i want to tie up some lose ends. i am going to install pst front end suspension kit(includes: upper and lower control arms,inner and outer tie rods idler arm, stabilizer link, sway bar bushings, strut rod bushings control arm bumpers),shocks and struts, leaf springs, and Tin Man Subframe Connectors. i just wanted to know if i was leaving anything out. Should i also do a sway bar kit and if so what size diameter
i currently have a 9 inch 28 spline 3:55 posi rear end with 255 45 17 in the rear. i could still fit a biger tire in the rear maybe 275 40 17 if i need more tire but i will deal with that when i get to that point.
